Originally posted by lyubodelev View Post
Brush by USB Burning tool!
The first boot is long 5-10 or even 15 min. Be patient and wait (the screen is black). After that leave the box to prepare all the preinstalled apps.
The rest I will send you! Wait!
Update using this link, in ordet Play store and YouTube to work
https://www.dropbox.com/s/zwidq037re...36%29.apk?dl=0
Tell me,when you have done everything to send you proper TWRP!
I installed this firmaware, I made the update, and it looks interesting.
I now have a serial number with "0123456789abcdef", whereas before he was at "Unkown", I would like to know how?
I can not install Netflix, and the browser in the first menu does not work.
Thank you and excuse my english
Originally posted by crandor View Post
Hi
Install the apk from the Dropbox link.
Some programs may not work since the firmware is made before more than a month and they have to be updated.Last edited by lyubodelev; 06 October 2018, 21:21.
Good Morning.
I have an AS1002T Asustor NAS and concentrated all my media on it. I can access the shared folders by Windows 7 64-bit, ES File Explorer on the smartphone and Kodi on the Xiaomi Mi Box. But I can not access by Alfawise H96 Pro + with this ROM. Both the FTMC and Kodi receive the "Connection Time Out" message. And the ES File Explorer repeatedly asks for username and password and never enters the shared folder.
I reinstalled ROM a short time ago, I did not root and I have only a few applications installed (Netflix, Youtube, GloboPlay, Crunchyroll).
What's the problem? How to solve?
Originally posted by eXcer View Post
So what could be happening?
The strange thing is that FTMC and Kodi can access a shared folder on the Windows 7 PC.
First of all i cant praise enough for this rom (7A). Its simply awesome!!!! It fixes so many stuff compared to stock. However i one question and i cant seem to find it anywhere in this thread, was support for all cores on 1.5ghz and GPU OC dropped since v1 , i cant even seem to find it in changelog. Is there anyway i can have kernel from version v1 to try???
Sent from my SM-A310F using Tapatalk
Out of curiosity, I ran speed test on the box. I am using 100 Mbps fibre broadband. The speed test I got are as follows :
2.4G 88-103 download and 60-80 upload speed
5G 98-105 download and 80-90 upload speed
LAN 50-70 download and 30-50 upload speed (with modem wifi switched off)
I though LAN speed should be better than wifi and not the other way round. I am using cat 6 network cable. Is there any setting in the box that hinder the LAN speed.
Test run the LAN speed on laptop connected to the modem using the same cat 6 cable and got 100 download and 95 upload.
I can't for the life of me seem to flash SCV4 on my h96 Pro+. I have the green PCB (CZ-S32-V2.2). I've tried 3 different versions of the USB burning tool with 3 different USB cables on 2 different windows boxes and always end up with an invalid checksum at some point. Usually it's pretty early in the process but one time, it reached 96% before hitting a checksum error. The md5 of the downloaded SCV4 images checks out.
I found a Linux flashing tool and I managed to complete the flashing process one time and one time only. On startup, the box hung on the SuperCeleron splash screen (left it for 20 minutes). I haven't been able to re-flash the device on windows or Linux. I've probably tried 40+ times at this point. Does anybody have an suggestions? Not sure where to go from here. Thanks.
Originally posted by Henngel View Post
I don't want the remote in my car. The touch screen is easier but needs navigationbar so I can go back and go home from other windows and apps.
I added touch xml file from a nother rom but no difference.
Beside the navigationbar disappear .
here's a video shows how the box responds to touch! !
Anybody else come across a h96 pro + board that will only boot a select few ROMs? This is an older model cz-s32-v2.2, 20161012(A15) QL 1648. It's marked as a 3G/32G/9377. I can flash stock Android 6 and SCV2 which is also Android 6. i.e.)
-- aml_6.0.1_s912_q9377-H96PROPLUS(3+32)_mac-2016xxxx.img -> aml_6.0.1_s912_q9377-H96PROPLUS(3+32)_mac-2017xxxx.img
-- SCV2-Alfawise.H96.Pro+.img
I can't flash any stock Android 7.1 and when I flash SCV4, it succeeds but it's stuck on the splash screen. I decided to pull TWRP from SCV4 and from SCV2 and boot via SD. SCV2 works whereas SCV4 does not. I'm curious what the differences in the board config between the two are. Might have to ping the builder of these great ROMs for that info. Chips on this board look familiar to most working boards but something must be slightly different.
There are currently 1515 users online. 0 members and 1515 guests.
