Originally posted by lyubodelev View Post
Remove everything from the USB ports and try to boot again.
With the last Box there was no problem to flash the rom..
In USB burning tool which settings should be checked?
Erase bootloader or not? Erase flash...
Cold you kindly describe in detail?
I've installed burning tool version 2.16 (key ist copied)
Originally posted by djthomasgee View Post
Hmm no change..
Erase flash - yes
Normal erase
I use USB Burn. tool 2.1.2, or 2.0.8.
Erase bootloader - yes
Erase flash - yes
Normal erase
Ive tried it again, same result: The Box stocks at the Freaktab Boot logo. After twenty minutes Id plug power of.
Then I tried to enter the boot menu. TWRP openes.
I plugged power of and tried again to boot .. The Box stocks again at Freaktab Boot logo.
Then I tried again to enter boot menu. No TWRP.. Only black screen appears.
Have you any idea what this could be?
I think I have damaged the bootloader but don't know how to fix.
First of all thank you for your help and your time.
My advise is to do two things before anything other, you do not expect maybe, but:
1. Change the HDMI cable, connecting the box and the tv, and try another hdmi port on the tv!
2. Change the charging adapter with another (5V, 2-3A) and try to power the box with it!I
Hi all
I have an odd issue, when I power down the box, via remote, status bar or app, the box goes into a "stand by mode"
In this "stand by mode" there is a red led light instead of a blue one, the usb ports still have power on them and the most annoying thing is I cannot power up the box via remote, I need to unplug it and plug back the power adapter.
The only way for me to really power down the box and then power up via remote is via reboot, I usually use an app for that, I don't trust this reboot very much because it's done very fast, almost immediately, so it does not seem a safe operation where the apps are closed and pending data saved, and of course a real reboot should restart the box after going down.
Anyone with a similar issue?
From what it sounds like you need to adjust power off function in the settings. Either toggle from desired setting or set to desired setting.
so far the function to do standby Is exactly what the box is doing when powering off. I can download and have network functions on my box while In standby.
Seems that your system may have the setting corrupted or when powered off, the system has no voltage going to the secondary stage of system circuit, needed for standby and power off. The secondary stage powers IR receiver and possibly low power functions and memory.
First of all don't panic!
I mean other roms are working with the used power supply and hdmi cable.
There is no problem with the picture output.
As i told you from the black screen there was a signal on TV The picture was only black or better dark Grey. Like the box couldn't load anything..
Ive changed the cable and port: No change. The Freaktab Boot logo is there and nothing happens.
Does the rom need more power?
Depending on custom firmware and age of TV HDMI can throw off video when data detection is not valid. I noticed some odd video settings being passed during boot all the way into loading of the home screen. Had one firmware default to 480 for recovery, and another boot to 720 when at boot image was displayed. I don't like being annoyed by seeing my info menu popping up more than once while the device is used or booted up.
I think some TVs may not have 480 on HDMI, since 480 is not on the digital domain. Thus no image being displayed when a firmware try to push 480 on HDMI. Even though the TV is capable of 480, it probably has an internal analog to digital converter circuit to upscale from the RGB, S-Video, or DB-15 inputs on the back side.
you can flash recovery over the one installed by the firmware, you are using, as I have to remove the customised TWRP that is bloody awful at 480. Surprisingly for the customisation, it has no effect on the firmware, and should have been dropped, as a useless customisation.
Originally posted by lyubodelev View PostWhy don't you try to brush another firmware to see what will happen?
Runs without any boot or display problems. But I prefer the scv4.
I have flashed it for a friend without any problems (same hardware specs: lpddr3 32gb)
Does the Android TV firmware version for this box work? I tried flashing it using the SD card maker method and nothing happened. Then the box went into a black screen so I thought I had bricked the device. I quickly made the SCV4 sd card from this thread and slapped it in, still black screen. While looking around the forum for un-bricking threads it seems that the flash did work but I never saw it in the TV screen, so when I looked back after a few minutes there it was, the setup screen. My TV is old, 2007 old-Panasonic Plasma(a friend gave it to me for free so I'm using it until a mid range 4K goes on sale this winter). Anyhow, yesterday I had the SCV7 installed but it was freezing after a few minutes, I thought it was Kodi at first but then it did it on Youtube also, so I started looking for more firmwares and came across the ATV version.
Right now it has been playing YouTube for an hour with no issues on the SCV4 green PCB thats in page one here. How can I adjust my homescreen apps? Netflix/Youtube/Performanceinfo/Powermenu specifically?
I tried the LightHome launcher but want to try others also, anything you can pitch I'd appreciate it.
Cheers
my H96p+ is the 3/16GB ddr4 q9377wifi
There are currently 1955 users online. 1 members and 1954 guests.
