I flashed back the SCV4 + erase bootloader (sd card method) on my H96 3/32 S32-V6 LPDDR3 (blue)
then I flashed aml_7.1.2_s912_q9377-S912_LP_mac-20180409 + No erase bootloader (else it doesn't work)
All is working very well : ethernet and passthru (Kodi and MX Player ; doesn't work with VLC)Last edited by jcplu; 30 September 2018, 12:45.
superceleron (or anyone who knows how to pack an image):
Could you try to create images of the two SCV4-ROMs with HS2734A-WiFi-Driver instead of the Q9377-driver?
I have serious problems reviving my "obscure" 2/16G-Box with this chip now (rare black PCB).
I bricked it before, but somehow got it to flash the few HD2734A-ROMs that are on the mega-link
Because none of these ROMs is really working reliably, I fiddled around with it again, and it's bricked again and I had no luck starting a flashing-procedure over the last few days.
It seems that none of the few ROMs is complete (i.e. inkl. uboot-stuff and/or recovery etc.), so I'd really like to try a SCV-ROM
superceleron if i set system dpi above 285, the bottom navigation bar moves to the right side and only shows 1 button. Is there a way to force the navigation bar to stay at the bottom at higher dpi like 400?
Originally posted by BrandoR View Postsuperceleron if i set system dpi above 285, the bottom navigation bar moves to the right side and only shows 1 button. Is there a way to force the navigation bar to stay at the bottom at higher dpi like 400?
There are currently 2342 users online. 0 members and 2342 guests.
