    well hi guys, im going to get some holidays soon, so im going to see if i can update some of my roms.
    Please look at fixing the recent update of My5 is unable to play video, newest Youtube, YouTube TV and any of the newer versions of STV Player app fail to load and play. The old app, STV Player V3.5.2.3 is fully operational. Another app... newer versions of SBS On Demand fail. I am using a year older version.
    Also if you can figure out a way to get Ti Backup functional on the top right of the action bar. Missing search and unable to perform an action ticking the check mark, as It is missing.
    PS, some will like it if you add the stock DROID Settings, as it allows more display options.
    I am using it with your firmware, without any issues.
      Wait... what???
      This is great news!
      A few points:
      The latest blackmart app uses 100% cpu so don’t include it
      I'm using eve launcher, very nice with google background.
      oc and under clock is missing for me...
      not using atv but normal tablet like android version (scv 7a)
      maybe 5ghz WiFi force or choose???
      maybe show kbs up/down speed at status bar? And cpu usage?
      any voltage meter for usb? Maybe we can see if we need more current as Voltage drops?
      Android 8.1? What will we gain if at all?
      other than that I’m really pleased with current rom! Perfect!
        Please..please..please...ehhh
        Don't burn yourself out...holidays for you and the family.
          Hi to all I had installed this rom I have the green board. How to install root? Through the update app I can't Thanks in advance
            TWRP-->Install from zip
              Thank you so much!
                Having Netflix (running not on HD) and other cable company apps on my h96 pro plus, it has become the center of the house... so with external antenna and proper cooling heatsink it is running stable.
                but I would like to buy a second box... any recommendations for a new box? Maybe superceleron can recommend?
                  Mecool M8S Pro L 3/32 (with voice).
                  ATV user interface
                  Does Netflix in HD (4k With account?)
                  $70 U.S.
                  ***Amlogic s922 *** should be out in 2-4 months?
                    Hello,complete newb here. Will this firmware work on my Alfawise H96+ Amlogic S912 3/32 GB? I've been told that my board is T92.
                    Thanks in advance :-)
                      Previous page the same plate, or not?
                      Brush green img!
                        ATV user interface
                        $70 U.S.
                        Expansive
                        no extrrnal antenna
                          superceleron Please enable USB touch screen compatibility! I will donate for this feature alone! Name your price!
                            I use remodroid and it passes touch entry just fine via my tablet. Much useful when apps require touch commands, and do not support mouse properly.
                              Please review or shad more light
                                Basically it makes your phone or tablet into a WYSIWYG remote to your TV box. It is way cool, as you can be away from your TV and see every aspect while controlling it.
                                I recommend enabling double tap to zoom on the access ability settings of the box, as the handheld device will need it for some selections that appear tiny.
                                The only draw back is there is a 1 to 2 second delay for screen refresh, and depending on streaming app, it may cause a protection issue and drop the playback.
                                I use an xposed module to turn off protection flag, but it does not turn off HDMI protection over secondary display.
                                The app can run both over wifi and wired lan, though wired lan is a bit smoother, depending on how good your router can cross connect between wireless and wired connections. Some delay may be more noticeable between the connections.
                                i use an older app, because my tablet is 4.4.2, though the latest version seems to run on the box, i chose not to, as i like the older version interface.
                                It is on the Google play store and apkmirror site.
