Originally posted by chenrp View PostHi,
i replace the internal antenna with an external one and i am getting 2.4Ghz wifi connection.
before the replacement i connected to the 5Ghz connection.
i don't have an option to choose prefered network (5GHZ or 2.4Ghz).
i have root...
how can i choose or see all the 5GHZ connections?
is there an option that the external antenna is 2.4Ghz only?
Hi all,
After testing the AlfaWise H96 PRO+ on SC's 7A rom I decided to try some HEVC video files. This was somewhat disappointing as colors looked pale and washed out. Contrast and general brightness was also way down. I've been told this a common issue on android boxes. Has anyone else found this especially when playing HEVC files?
If so are there any easy fixes?
If your TV does not reproduce 10 bit or 444 properly, it will look washed out. Depending on TV architecture, mid range to low cost displays are problematic. When you pay for a top of the line model that is HDX certified, I doubt you need calibration done, when properly set up.
Try Vimu media player!
http://4pda.ru/forum/dl/post/13553861/Vimu Media Player [6.80].apkLast edited by lyubodelev; 10 August 2018, 18:23.
Thanks for the response guys. I must admit I've not experimented with the various media player software yet as I assumed the issue may be with the hardware or even android 7.
I've used MX player before on other devices but not Vimu. Are there any settings on this player that are needed to achieve good HEVC playback?
Originally posted by Modelman View PostThanks for the response guys. I must admit I've not experimented with the various media player software yet as I assumed the issue may be with the hardware or even android 7.
I am on SuperCeleron SCV7a which has all the codecs fixed. He has proven HEVC works, and sez the output on these boxes are as good as his Shield TV.
Maybe you should invest in a DVE HD Basics bluray. H264 8bit is different than h265 10bit, they can exist together in how the decode is setup on the processor on your projector.
I have a DLP rear screen display. Similar to a projector, but self contained.
The bluray will assit in a proper calibration with setting up for decode of 10 bit samples, even if your projector can only do 8bit at 4444
you need to identify your highest level of input your projector can do, and setup your box to keep that format, and not adjust outside of that.
Many complain about unable to get auto pull down function, but in reality most displays aprnd projectors do not have separate decoders, only one to do all decodes. So as long as you have calibration options you can fine tune and get the best picture.
My TV can do 444 10bit internally without conversion, most older sets can only do 422 10 bit with conversion up to 444 10bit, or only 8bit which RGB must be used.
Some projectors do better in RGB, depending on tech being used.
well anyway... The bluray will take you to the basics and assist you into greater details in fine tuning. You will need to obtain info on your projector factory settings, usually in a hidden menu. You may find that info on the net, via forum on your projector. I use to follow the avsforums when i first got my TV, to obtain what i needed to know. Some devices can use the same settings as others who post their settings, so no guess work on your end.
hi.I have a problem and i want your help.i install the green firmware to my box with burning tool and everithing went ok.i start the box and i tried to update with sd card but the box shuts down and never restarts.i tried with two different sd,with usb stick but always the same.shuts down. Have any of you an idea how to solve this problem?p.s.sorry for my poor english.
There are currently 2852 users online. 0 members and 2852 guests.
