Don't wory, YouTube will be updated.
For 4K and 1080p try Smart YouTube and NewPipe.
Don't wory, YouTube will be updated.Last edited by lyubodelev; 14 June 2018, 14:48.
Originally posted by gintaras41 View PostHey guys, i was wondering, if ill flash this custom Rom to my android box will its mac adress change? Couse i have brought Smartip tv app which is registered by mac adress, any tips how cna i save same mac?
Download from the market Terminal Emulator, open it and write the fallowing:
su
echo "mac" > /sys/class/unifykeys/nameecho "c4:4e:ac:19:3e:cf" > /sys/class/unifykeys/write
c4:4e:ac.... - replace with the desired mac address
Be careful with the spelling!
Originally posted by lyubodelev View Post
Yes, you can. The easiest way is by a terminal command.
su
Hello. I am trying to upgrade my green PCB with SCV4, but even after 20 minutes nothing happens. Just this screen.
It does not appear that the upgrade starts, as the original rom remains on the box and works.
What to do?
Sorry for bad picture and my bad english.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Samm View PostHello. I am trying to upgrade my green PCB with SCV4, but even after 20 minutes nothing happens. Just this screen.
What to do?
This is how it workss on my mecool km8 p.
What to do?
mark-1978
You may try, but there is fair chance it will end with a brick, as RAM is not the only component that have to be compatible (that's why some H96 doesn't work with this rom).
lyubodelev
I think this is stock Update app? Never used it, but it seems to be stock update process.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
I try upgrade to SCV4 with this tutorial:
http://freaktab.com/forum/tv-player-...o-any-s912-rom
Can i get some help please ?
How can upgrade from stock rom direct to SCV7 , without upgrade to SCV4?
Originally posted by Samm View PostHow can upgrade from stock rom direct to SCV7 , without upgrade to SCV4?
You will loose more time for reading such not tested articles, than to brush your box with the proved USB BT and to make the OTA Update for several minutes.
Is this guide ( http://freaktab.com/forum/tv-player-...o-any-s912-rom ) OK for upggrade stock rom to SCV4 ?
Originally posted by Samm View PostIs this guide ( http://freaktab.com/forum/tv-player-...o-any-s912-rom ) OK for upggrade stock rom to SCV4 ?
Here it is clearly said on page 1 what one has to do to install SCV7A, isn't it?
I'll ask otherwise, because you do not understand my problem.
I did everything in accordance with this guide( http://freaktab.com/forum/tv-player-...o-any-s912-rom) to upgrade the original ROM to SCV4 , but even after 20 minutes nothing happens.
I reset and try again and nothing.
What to do?
Is there other way to upgrade to SCV4 and how ?
There are currently 3631 users online. 0 members and 3631 guests.
