The last version from the market.
Originally posted by vaiosp View PostI already have TV outlook selected but it's not there... My version is 6.18.0.4847. Version 6.2.1.1036 is from July 2017.. I will try and find that version and let you know.. Thanks a million!
settings/advanced/player/obtional support!!!
Uncheck 1 and 2 checked items and you are ready!
nicoga97
http://freaktab.com/forum/tv-player-...roidtv-version
It is one of pinned threads in this subforum...ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hey guys
I just came back to working on my H96 Pro+ after a long delay. I did a fresh install of SCV7A (flash of V4A first then OTA to V7A). It all looks really good, and awesome to see ChromeCast Built In. Great work superceleron .
But I have a big problem: I can't install most of my Catch UP TV apps. BBC iPlayer, All 4, ITV Hub, UKTV Play, and more. They all say "your device isn't compatible with this version".
EDIT: I have instead used Aptoide and been able to install a number of the apps I wanted. I have installed BBC iPlayer, All 4, My5, ITV Hub and UKTV Play.
EDIT 2: Actually it might have been very simple - my region settings. I had Language: English (US). I changed it to English (UK) and now if I uninstall the Aptoide versions of apps (eg BBC iPlayer) I can install them via Play.
Simple as that, duh!There's still a couple of apps that say not compatible, eg Amazon Shopping, but they are not apps I need right now.
have this box from gearbest (green pcb) and installed SCV4
Since the beginning (without custom ROM) have the box stucked on the logo at the boot after 4-5 usages. I hoped to solve it by installing the SCV4 ROM but the problem is not fixed.
Only a factory reset can let the box work properly but after 4-5 usages it again gets stucked on the boot logo.
How can i solve it? It doesn't seem to be a ROM problem...
In order to solve the problem of my post #2304 i did the following:
- factory reset and e reinstall scv4 through usb burning tool --> didn't change anything
- wipe everything (included internal storage) and reinstall thorugh sd burn card maker --> bricked the device, blue light didn't turn on when connecting to power source. I solved it by following http://freaktab.com/forum/tv-player-...ck-help/page10 and reinstalling this old rom https://mega.nz/#F!d1tHVZgA!Qc0mAom7FBHT9HDv3rGtGQ, will see if in the next days i will re-encounter the same problem at boot.
There are currently 1273 users online. 2 members and 1271 guests.
