Are You sure it's V3? V3 supposed to be green as well. V5 and V6 are blue (and there seems to be new one with blue PCB). Look here: http://freaktab.com/forum/tv-player-...ponent-changes
V5 is (last picture of PCB in 2nd post) clearly more blue than V3 (second picture).
For Normal unofficial rom go to the first post of this thread. There are links for V4 Green and Bluer - You use Green, coz Your PCB is green. There is V7A OTA as well to be flashed after V4. To flash V4 either use USB Burning Tool and male2male USB cable or microSD method.
ATV rom is here: http://freaktab.com/forum/tv-player-...roidtv-version (here is V1 Green as a base rom and V4A as OTA).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostAre You sure it's V3? V3 supposed to be green as well. V5 and V6 are blue (and there seems to be new one with blue PCB). Look here: http://freaktab.com/forum/tv-player-...ponent-changes
Crusader007
Maybe like this? https://i.iinfo.cz/images/525/h96-1-prev.jpg
It's the 2nd picture from that thread and this is V3 PCB.
As for V7A, than it's in the first post - it's first link in download "section" (above the V4 green and blue links).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Push the reset button. For me it took 3 or 4 tries with reset button for Burning Tool to flash without errors.
If You didn't click Stop, than it should restart flashing right after devices will be rediscovered.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
ch3mn3y Hi mate, it apears to be flashing it now, after about 5 attempts.
successfully flashed the green rom, just booting it up now for first time. then what do i do to get the ota update mate?Last edited by Crusader007; 10 May 2018, 16:53.
There are currently 2945 users online. 3 members and 2942 guests.
