Reboot to TWRP - turn off the Box, disable power cord, push the reset button with pin, connect power, push the pin for ~5 seconds more. It will (should) boot the TWRP recovery. There You can flash V7A update and MAGISK (after update). Or You can flash zip with SuperSU (installing app is not enough as app is just an interface).
plaetter23
Reboot to TWRP - turn off the Box, disable power cord, push the reset button with pin, connect power, push the pin for ~5 seconds more. It will (should) boot the TWRP recovery. There You can flash V7A update and MAGISK (after update). Or You can flash zip with SuperSU (installing app is not enough as app is just an interface).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
@ch3mn3y
thank you. I´m now in TWRPwith working mouse. Shall I 'restore' now with SCV7A from http://freaktab.com/forum/tv-player-...7-wifi-chipset ? Does this work with blue PCB?
Originally posted by ch3mn3y View PostWhat's the problem with the clock?
Remote may not work, as I see it's to different than H96 Pro+ one. You may try to use remote.conf file from official firmware fot Zoomtak on this Rom. It may work better, as it would map all buttons to correct actions.
thanks
have this box from gearbest (green pcb) and installed SCV4
Since the beginning (without custom ROM) have the box stucked on the logo at the boot after 4-5 usages. I hoped to solve it by installing the SCV4 ROM but the problem is not fixed.
Only a factory reset can let the box work properly but after 4-5 usages it again gets stucked on the boot logo.
How can i solve it? It doesn't seem to be a ROM problem...
Twisted714
Clock as te timer or somekind of bootlogo/bootanimation (don;t remember original ones). Coz if there is working clock-timer, than software have to be working, so not sure what can be a problem. Bu if it is logo or animation, than You have to reflash the firmware or Your box may be not supported.
frenky_minkia
Did You install something? It may be a cause of the bootloops.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
ch3mn3y i have restored the original firmware, what I really am looking for after all this flashing is a notification bar. The modded roms all had it. I've tried many of the roms, gt1, h96, vorke, if it said q201 anywhere that I was reading, I tried to flash it.
Magendanz worked the best, but no display.
Superceleron was the fastest.
Is there a file that I could sideload that adds the notification bar?
frenky_minkia
Not sure, but it seems that SuperSU i somewhat incompatible with our Boxes. Better move to MAGISK.
Twisted714
If You move to cursor near the bottom or top of the screen and move it left and right or click with the left button (of the mouse or AirMouse) doesn't it show up? Not sure how it is with stock firmware, but in this rom, both navbar and statusbar are hidden as long as You don't hover over place they should be.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by superceleron View PostEDIT: One more update...
Many Thks to my beta tester's trebor and scooter2014 !
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
UPDATE LIKE THIS - SCV4 (IMG) -> SCV7A (OTA) (ALL OTHERS THAT ARE ON OTHER VERSIONS YOU CAN UPDATE JUST FINE )
ON IMG INSTALL CHECK IF YOU PCB IS BLUE (LPDDR3 PRINTED ON THE BOARD) OR GREEN AND FLASH THE CORRECT IMG.
Enjoy it!
Originally posted by Bebe1980 View PostProbably being a bit thick here - After I've installed the SCV4-Test1.img (for the blue pcb) do I then install the SCV7A for the updates and fixes ?
There are currently 2719 users online. 2 members and 2717 guests.
