It's not this Rom thing, it's Android thing. Any device has this menu, but as it's for "developers", it's hidden. And there are many useful options - since 8.0.0 even more, like ADB over TCP (useful when installing files from .apk, With it it's [possible to do it over WiFi from other device).
Ace310
It's not this Rom thing, it's Android thing. Any device has this menu, but as it's for "developers", it's hidden. And there are many useful options - since 8.0.0 even more, like ADB over TCP (useful when installing files from .apk, With it it's [possible to do it over WiFi from other device).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by lyubodelev View PostAnd here is the file:
https://www.dropbox.com/s/ki99f0c0jy...k-res.apk?dl=1
Don't try to use the hole file framework-res.apk from ACV4, cause the box will come to a constant reboot!
You can see the mouse pointer here:
Thank you so much! I ended up keeping both Frameworkres.apk files in case i ever decide to go back to the black cursor. Looks so much better with a dark background and dark wallpaper.
in case anyone wants the dark launcher : https://1drv.ms/u/s!AvHIU35T8haBj0kmpNuP9MIIUCnfYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by yusman View PostWould anyone have an idea to fix this problem please.
Originally posted by chenrp View Post
superceleron
Fixed H265(HEVC) 10Bits playback ( Tested 1080p and 4K samples )
i heard this common bug/problem with android 7 is that true ?
There are currently 2201 users online. 5 members and 2196 guests.
