i can acess and write on external NTFS HDD! very cool
Hi superceleron, for the S912 overclock 1.5Ghz 8 core and gpu 792 is the same for all, I mean, it is written in a file that can be replaced on any firmware? sorry my bad english.
Thanks in advanced.
Frequency specs are probably in some table with corresponding voltage in kernel. However if You want to lower the max frequencies of CPU and GPU cores, that You can create init.d script, or use an app like Kernel Adiutor, which will do it for You.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by Padrino75 View Postsorry for being noob and/or if it was already adressed, but i`d like to ask:
1-Will this firmware work on Vorke Z6 plus 3/32 DDR4?
2-If so, which shall i choose, Green or Blue?
Many thanks to all
2. blue
Originally posted by lucabis View PostI transferred the discussion here
but why can not you immediately flash v7? so if I understand magisk, it's no longer needed.
As for why You cannot flash the update, I don't know. There was no problem for me and none for a lot of other users... Maybe bad flash of SCV4? Maybe something with the Box? Hard to say.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 2025 users online. 1 members and 2024 guests.
