Enviado desde mi SM-G935F mediante Tapatalk
Originally posted by nicoga97 View PostHello I installed this Rom but when I install Android tv version apps like spotty or Netflix it force close any solution? Thanks*
Enviado desde mi SM-G935F mediante TapatalkLast edited by lyubodelev; 16 May 2018, 10:03.
Originally posted by lyubodelev View Post
Android TV verson applications are for Android TV firmware. So don't try to install them. Install only normal versons.
On my tv CEC is on, but I want to know how I can turn on and of my tv with the box, I mean with is the command,button,etc with let me do that, Thanks!
1. Turn on the box, wait till Android starts, and the TV will power on automatically.
2. Turn off the TV and the box will shut down automatically.
Hi everyone,
i'm having issue with youtube...
after running kodi and more apps, and after closing all apps, i get black screen on youtube.
only reset will help and it is hard reset as i can't reset the box with any app.
any memory killer you recommend?
i see that in SquareHome 2 launcher they have a fast task killer?
thanks
thanks
Instead of YouTube try Smart Youtube (t°!), or NewPipe.
Replace the old tube with a new pipe!Last edited by lyubodelev; 16 May 2018, 18:30.
Originally posted by LodestaRgr View PostBut you cannot take the HDMI-CEC from Mi box 3 (global) and record on SCV7A and SCV7ATV firmware? There it is perfectly implemented, all control is from the original remote (tested on LG-simplink and Philips)
As you can see this is my first post!
I Only wanted to thank all of you for the posts and Superceleron for making this possible.. I got a "noname" H96 pro plus from BangGood. 3 - 32 GB which came with Android 7.1.2 and build number NHG47L.20171129 test-keys. AIDA64 was telling me "Device Model - Alfawise H96 Pro+"
This particular firmware was excellent. no wifi issues, no brightness issues, no sound issues , I was VERY happy with it apart from the fact that it was rooted. So my sat provider app wouldn't work (Cosmote TV GO) Overheating issues were resolved by modding as I cut the box and added a heatsink and fan from an old P133
I searched in the forum for the most "compatible" firmware and ended up in this thread. I hadn't done it in the past "change firmware to a tvbox" but I am familiar of firmware flashing on Samsung phones.
Superceleron recommends flashing with the USB Flashing tool but I went for the SD Card maker method that had read in another thread. I used a 4GB SD card which I first formatted and then created it. Flashing went well and fast, OTA update was performed without an issue as well. It will take some time to get used to it but I will manage!
A few notes!
1. Is it a hardware limitation ? Neither this , nor the original firmware suports AC3 audio in movies played through the Plex app. I used the Plex plugin in kodi to play them with sound.
2. When adding my google account , in the email input ,the virtual keyboard was nowhere to be seen.I couldn't even long click and paste my email! I had to connect a USB one to pass that screen. on the next screen (password) virtual keyboard was there again.
3. I wish there was a link for the usb flashing tool in the OP it took me quite some time and research to locate it with instructions on how to use it (although I didn't use it in the end)
4. and since the SD card procedure works well why is it not reccomended?
Thanks again!
Originally posted by vaiosp View Post1. Is it a hardware limitation ? Neither this , nor the original firmware suports AC3 audio in movies played through the Plex app. I used the Plex plugin in kodi to play them with sound.
Thanks again!
2. Help yourself with the stock remote.
3. It is not a problem to find this tool using Internet.
4. Because sometimes, though working well, you can brick your box with it (4 times greater possibility this to happen, than using the USB Burning tool).Last edited by lyubodelev; 22 May 2018, 10:23.
There are currently 1374 users online. 1 members and 1373 guests.
