On my H96 Pro, I lost the microsd card inside, turns out the microsd slot had lifted so i could not see the card, when i took it apart, there was only 1 screw holding the motherboard down with 3 empty screw holes, I fitted the missing screws and my microsd slot is a lot better aligned now.
John.
Originally posted by grlskce View PostNope, Poland here
new idea: cut hole under h96 for 1cm height fan, cover bottom ventilation holes, make a new holes on top for hot air exit
PYROMID
idle 35*C
loaded 50*C
i have a friend with a 3d printer...
anyone wants to send me a file and i will print and review here?
anyone tried to connect a fan to the two pins on the board? the two pins next to the LED...
thanks!
Originally posted by Newfie Chick View PostThe only thing about this hardware that I don't like personally, is dispersing the heat generated by the processor. Any recommendations on size of heatsink AKA radiator?, With the cover closed. Also thermal pad or paste
Thank you,
NC
so if you mod the case, you won't throttle.
but,
the case has no vents on top. i think that a heatsink won't do. just add fan/vents...
i will try putting copper adhesive and see if there is a temperature chage.
There are currently 2242 users online. 1 members and 2241 guests.
