Originally posted by wwmoggy View Post
you could try it and see install as OTA local file ( BACK UP FIRST JUST IN CASE )
and i also asked there on the Google+ page and now i know: this themes are independant of the rom and device you use, important to have minimum TWRP 3.1
i like it, very easy to install and use, working good and i tried already crDroid and RR theme on my tablet.
i like the menus, easy to get to the file manager, but i did not try yet a backup for example or install some other rom. but it might work the same way, because only theme is different? or what you think?
but ok, i will not go further with this here, more important for me is a new update of the SCV6, which is a so fantastic rom.
my tv-box don“t freeze more, before on stock rom, every day it was freezing and i had only the option to switch power off, now i relax, thanks once more superceleron
Well you are using mouse or airmouse to select the update etc?
I was using mouse option from remote control then I plugged a usb mouse
I dont have my tools to measure power output but I suspect problemis coming from the last batch of poswersupply
I decided to power the box just with a usb cable connected to a laptop (nothign else no power supply) and then all seems to work the way it should, a few little glitches but could reboot, in recovery, reboot normally and all features are working . maybe power supply or power jack is having an issue ... I have that on 2 new boxes that just arrived
I have to check more if the problem is coming from the power supply or the new batch of motherboards
After another reboot even with usb only things are crashing again, very strange ..
I flashed a few times always success but .. unstable,
Originally posted by wunga View Post
Hello SC
superceleron i know you are very busy, but as i did not get any answer i like to put my questions once more here (i am waiting more from other users any answer) -thanks
Dolby Atmos
I use Dolby Atmos on my 2 tablets (Lenovo and Nexus 7) and i like it very much.
superceleron can i flash a zip-file with our installed TWRP , I thought in this https://forum.xda-developers.com/app...2#post73816841
or is there other dolby atmos zip which i can flash?
Launcher
where in the settings can i change the launcher?
Originally posted by tombraga View Postsuperceleron i know you are very busy, but as i did not get any answer i like to put my questions once more here (i am waiting more from other users any answer) -thanks
Dolby Atmos
Launcher
only 1 didn't give me problems. Apps crash, loops , freezing . Tested both SC roms, even new atv ons, same problems .. Even tried a plain customized one, freeze .
Gonna try to open the ones and compare with what I got around ... or they go in the bin
Yeah there is definitely an issue with those new Alfawise from GearBest - Tested about 8 diff roms
@ wunga - I really dig superceleron's firmwares. SCV3A-ATV and SCV2-ATV-GT1_Ultimate. Dont get me wrong, SCV6 7.1.2 seemed smokin' fast and I really wanted to use it. But Sling TV, which I pay for, has video problems and a few other apps show symptoms that you posted about. Android 6 is not as snappy, but more stable for my Alf H96 Pro+. Good luck! Hope it works for you.
wunga - I should clarify, Its not Superceleron's 7.1.2 roms specifically. Its any 7.1.2 rom. Stock or custom that causes problems for some apps on my tv box.
There are currently 1559 users online. 1 members and 1558 guests.
