When we are talking about Routers I have Mostly Atheros AR9344 Based Routers since they work as a Bridge, But it seems that wifi is an Issue at least with the qca9377 Chips for this wifi chip set you are better off with a Broadcom chip based Router, The wireless works better for the 9377.
I have most of my Computer equipment in the Basement it is cooler there so I use a Bridge to get access to the Main Router on the Main Floor, Then I use another Router just for vpn access.
I was just using the Atheros Based routers but was having issues with some boxes and wireless connections since I changed the router to a Broadcom Router that issue has vanished.
Just a Note I use dd-wrt on all my Routers.
Originally posted by tombraga View Post
what do you mean with fire update tool, where i can find the tool? is this a app which i have to install first ?
I am sick
Originally posted by wwmoggy View Post
the update app on your android open it select local up date then select the scv6 OTA file zip file next confirm your box will reboot and install the update its not rooted . read the posts here on how to root it .
I am sick
So there it´s clear for me, how to flash supersu for example, but here with the tv-box, it is different.
Also i tried to find out if it is possible to update/install from original Android 7.1.1 which came with my box directly to SCV4?Last edited by tombraga; 15 September 2017, 20:03.
Originally posted by ReaperMan View Post@ tombraga,
Just a test....With Burn Tool visible, when you attach usb cable, does your windows detect your device and Burn Tool display port connection?
If your drivers are successfully installed then you are good to go. Detach cable and start my suggested procedure.
Reap
The installation of burn tool was running well, also said, that the drivers are installed.
can you put a picture here of the burning tool, what should be shown when i connect the tv box with the pc by usb-cable. thanks a lot
in the meanwhile i could install the SCV4 rom and then i wanted to install the SCV6 version. I opened the update app and choosed the downloaded ota zip-file and started the update. And it seemed that everything is updating well and it restarted. But then i checked the verison and continued with SCV4.
Don´t understand why, what i did wrong?
is it possible in the scv4 version to reboot in recovery? if yes, how i do it? i only can find the normal system reboot.
Perhaps i could zip the scv6 zip-file in reovery mode?
Originally posted by tombraga View Postin the meanwhile i could install the SCV4 rom and then i wanted to install the SCV6 version. I opened the update app and choosed the downloaded ota zip-file and started the update. And it seemed that everything is updating well and it restarted. But then i checked the verison and continued with SCV4.
first did you follow all the Instructions correct ??? Maybe this helps :
for Reboot to Recovery u can use a RebootApp from Store , Example : Reboot by Petrus , good App ,
but Root is needed . good luck / gefattern
now my SCV6 is working fine, root with magisk 14.0, my favorite launcher nova prime is also running smoothly, very happy until now, thanks a lot superceleron
superceleron és um grande artista, muito obrigado e abraço de Braga
here a print of my actual situation
is it possible in the settings to deactivate the symbol that wireless is not active (see red marker). I have always wireless not active because i use ethernet cable.
cannot add clock widgets, i tried this https://play.google.com/store/apps/d...ckWidget&hl=de and this https://play.google.com/store/apps/d...rt.clock&hl=de
when i try to add the widget to the main-screen, settings were closed
in the stock-rom also with Nova Prime Launcher this was no problem
Originally posted by tombraga View Postcannot add clock widgets, i tried this https://play.google.com/store/apps/d...ckWidget&hl=de and this https://play.google.com/store/apps/d...rt.clock&hl=de
To remove the wireless icon on top just go to settings and disable Wi-Fi!
Thanks for your great work to bring us this Custom Rom.
As i am a user who like to have the Status/Navigation Bar always on, with the opportunity to let it vanish by need, i´m not too happy to see that there is a autohide for the bar after 3-4 seconds. Is there a possibility to change that manually? That i can switch off the timer? Or will there a option in a future update to do so? I would greatly appreciate this feature.
Ty
There are currently 3360 users online. 0 members and 3360 guests.
