@ Blegis,
Magisk has been updated to v14. Is this the version you are using?
The indicator in Magisk unable to find root....I've had/ have the same thing. It did work for a bit now shows "can't find"... Modules install so...might be ok.
Safetynet is a module, with the update to v14 (v4 code) Safetynet may have to be re-coded/updated. Look to the download modules in Magisk. Safetynet.v1.?? was considered outdate and beta 2.??? may not be updated?
If playstore services..etc crash, it will show Safetynet error.
P.S. UI crashes? are you using default launcher? When does it crash..events..apps installed? More info gets more help!
Reap
@ JoseM,
Adaway..are you rooted?
If your using Magisk...check out here forums...briefly saw info there: https://forum.xda-developers.com/apps/magisk
Something about selecting systemless. I'm not sure other wise maybe someone else here has experience.
Reap
Reap
Originally posted by Ace310 View PostWill this work on this box (H96+ pro)? what is SCV...? which version should I use?
For now wait until tomorrow for me to rls scv6, then you 1º flash the img and then the OTA....
ALL: SCV6 Cumulative is done i just cant post it now since we are having some file server problems... lets hope tomorrow it will be fixed!
Ok Ace
First off you posted this elseware. Yes this should work on your device also the Atv version should work. Before posting everyware take some time and read the posts your like alot of others. Some risks always flashing. Look at wifi chip and see if matches yours. Dont keep posting same thing in different places ok. Enjoy.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Yes it should work just fine in that one!
You can close all other threads or merge them if you want.
Edit: I closed other threads. Cheers.
@ JoseM,
This info may help with adware and Majisk 14.0
If you learn anything..please share back.
This mod has since been discontinued in favor of Adaway. Read on for information on how to use Unified Hosts with Adaway What are Unified Host Files? Unified host files combine many reputable sources into a single hosts file (with duplicates...
Reap
Originally posted by chenrp View Post
i couldn't see any vents on this box...
any nice looking mod?
sry but all i have seen are very ugly...
Hi. My mod: heat sink form old motherboard
idle 52*C
loaded 72*C
planning to add fan and build cover using PCV 2mm sheet
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 6376 users online. 4 members and 6372 guests.
