If I need to delete my previous post, I will gladly do soo..thanks again Wwmoggy!
Hi guys,
Great work with the ROM . Works amazing
One small thing (issue I am having). Hopefully someone can figure this out because I can't.
I use the Sportsnet now app (from Canada). Allows me to live stream sports. I have a legit subscription
When i was on stock firmware 7.1.1 I was able to stream in HD no problem. Very clear picture.
Now that i'm on this firmware the feed only comes in what looks like 480p.
I did nothing to the app and changed nothing. Just the same download and log into credentials. But not only shows up in sd quality.
Anybody have any ideas what this could be.
The build prop to which version i'm downloading?
Maybe the bitrate is locked to only stream lower quality on the rom (not sure if that makes sense)
Thanks in advance guys
Hoping to figure this one out
Thanks SC
1º About the codec sleep, try to go to settings -> screen saver and change "when to start" from 5 min to 2h.
2º looks like that reboot app have problems with some usb sticks, use a sdcard if you have that problem... the sdcard need to formated as FAT32 and the update should be in the "root" of the sdcard.
3º option, attach a mouse and load the update to the update app and update, that will boot to recovery and then go to the mount -> "mount usb-otg" select it, go back and go tp "install" and "Select Storage" in that selete "USB OTG" the mouse lags a bit dont worry is normal, press ok and voila you will see the update zip... now just select it and flash it and in the end reboot... easy!
Can anybody help me I installed this firmware on t95z and it works like a charm... totally smooth everything works great...except two things
1: I am facing one issue in kodi 17.3 and 17.4 that whenever I enable passthrough I hear nothing from my speakers... My led is attached to my AV reciever... Is there anything someone can help me with?
2: Secondly if I install youTube Leanback app instead of the default Youtube app in this firmware( cause it doesn't gives an option to select resolution) , I can't get to select the 4k resolution?
Originally posted by yudi.15 View PostCan anybody help me I installed this firmware on t95z and it works like a charm... totally smooth everything works great...except two things
2º dont change it, you only get 4k on the included one... that included one is the new YT leanback V2 and is auto sensing it detects your resolution and internet speed and changes it to 4k if you have the correct parameters, just like netflix on L1 devices!
Well im working on it... im really getting annoyed of this box/rom...
Thanks a ton in advance ..
Originally posted by superceleron View PostLol in only annoyed because i should be working on other stuff by now...
well i have rls a test build to test the passthrough, but is ATV version.... if anyone is on ATV version plz test it and i then port to this one!
Where can I get the test release?? I am on ATV version already
There are currently 1346 users online. 0 members and 1346 guests.
