Originally posted by fannar76 View PostHas anyone had the problem with this build when it loses signal with tv and you have to unplug the power supply and plug it in again?
iam using 5v 2A power adapter
Originally posted by valencia7514 View Post
yes, it happen sometimes when i plug the hdd external to the tv box while its on. losing signal and you must restart the box
Ok. Thanks for the answer. So maybe the problem is the power supply? Where to order a new one with more voltage/amps for the box?
For those of you that have old mobile phone chargers, these can make good power supplies providing they have enough current output. Just chop of the Apple or micro USB connector and replace with a DC power connector. Make sure you check polarity before connecting.
OUUUUH YEAAHHH!!!
It runs on Mecool M8S Pro 2GB/16GB.
The only what have no function is Ethernet
Hope there comes a fix or someone can give me tip how it works.
Thanks! superceleronLast edited by SemNizzle; 21 October 2017, 20:57.
Originally posted by Modelman View Post
Probably the power supply. A few amps can surge when first connecting a Hd to the USB port.
Hey SC
Great job with SCV7 works great
Only having 1 problem wondering if anybody has the same problem
I am using Ethernet connection and find that every once in a while after the box has been sitting in sleep mode the ethernet does not work. Shows that its connected but I don' have an internet connection. I have to unplug my Ethernet cable or restart the box to get the signal back up.
Has anyone else experienced this
superceleron I have installed SCV2 I think, yesterday I wanted to update to scv4 and then to 7, what is the proper way to do that? i tried to use burner card on scv4 but had this error
Sent from my ONEPLUS A3000 using Tapatalk
There are currently 1373 users online. 0 members and 1373 guests.
