    Originally posted by ReaperMan View Post
    @ deviltheturtle,
    Try 4pda. I saw test keys for one of their firmwares. Make sure it is for H96 Pro+, the earlier pages discussed H96 Pro.
    You have to put the key into the USB Burn Tool folder( before turning it on?)
    I can't find any key for download my tv box there russian site it's hard to understand their language .
    When im using stock roms In the Usb Burning Tool always displaying (mac 0) in the right box.
    Where can i find keys to download?
ID:	676894Click image for larger version
      Click image for larger version  Name:	Adsız3.png Views:	1 Size:	233.3 KB ID:	676894Click image for larger version  Name:	Adsız4.png Views:	2 Size:	237.7 KB ID:	676896
      weird, you only have 2 usb port?
      i think you get the new revision of the box
      it seem you get the same problem like totor54
      http://freaktab.com/forum/advertiser...fawise-h96-pro
        Originally posted by incrovantilist View Post
        I went and edited the key codes file corresponding to remote.conf keys to add APP_SWITCH (recent apps) keycode. Now whenever I click the mouse mode button I get the recents menu but the mouse mode gets activated too. I want just a little help. In the remote.conf which keys correspond to the APP & SETUP buttons. I went through a dozen Linux key codes list and other remote.conf but I'm not getting anywhere. Please help, this can be done.
        Edit - For now I've set the '0' button to act as recents button. There is no way as of now to select the clear all button. Individually the apps can be scrolled with the arrows and removed from recents using the Backspace button. I'd call this attempt a success but still I'd like to know the keycodes of the APP & SETUP buttons.
        well i dint look in this one, i totally forgot this one is not the stock one and yes the APP_SWITCH is there... i totally ignored it because i was thinking in the old rom... that was there but not working!
        you want the setup button to call APP_SWITCH?
          http://freaktab.com/forum/tv-player-...0830-test-keys
          Yes looks like he have a new revision...
            Morning all,
            After upgrading to SCV 7A - suddenly the home button om my usb remote no longer seems to work? (Everything else works perfectly)
            Any ideas how to resolve this?
            Thanks in advance.
              TVLauncher works like a charm and great to customize.
              TVLauncher 3 ist eine kundenspezifische Trägerrakete von Grund auf für die große Leinwand gemacht.
                @ deviltheturtle,
                Take a peek at post 32...research first...I'm doing this on the run.
                  I jumped from SCV4 straight to this (SVC7A) but i am really missing the Android TV launcher, and was surprised it booted into a new launcher(s) on its first startup (i totally appreciated i may have missed the whole point of this version) ... any way of getting back my lovely launcher from SV4 but keeping this revision?
                  or will i just flash back to SCV4?
                  Thanks in advance
                  • superceleron
                    superceleron commented
                    Editing a comment
                    I think you messed up roms m8... the rom you want is the SCV4 ATV version and that is another thread, this one is the "Normal" one... see tittle on of the threads!
                  Yes Mate, That's all I want now. Even if not for APP_SWITCH, I'd like to know the keycode for APP & SETUP buttons. I'd like them to execute other shortcuts.
                  • superceleron
                    Editing a comment
                    Ok i will check it... i will make the app button APP_SWITCH and the setup in to settings in the next version.
                  Hi. I just installed SCV4, and it is not rooted. How can í root?
                    use Magisk v.14.2
                      use Magisk v.14.2
                      Ok. Thanks. Can you tell me how to install it?
                        you can install magisk using twrp
                        how to enter twrp = power off your box -> press the reset button using toothpick ( and hold it ) -> plug in the power adapter. hold the reset button until your box enter recovery menu
                        in twrp choose install -> magisk
                          1º did you enable it in settings? and i cant test it i dont have a HDR Tv...
                          2º m8 i dint add them...
                          3º you have the same problem i have in mine... i bet if you leave your powerdown its hot
                          Read/search the forum theirs a lot of info in here.
                          But i can tell you... recent apps list button need to be added to the source... and is not added on this one so.. forget about it!
                          1 - Yes it is enabled in settings. I think it is limitation set by google on TV app. I tried with Youtube mobile app from Play store and HDR works. Its bit annoying to use mobile app as remote arrows don't work with it.
                          2 - As requested by incrovantilist, could you please provide details of setup & app button.
                          3 - Yes it is hot with powerdown. I did few tests with this. On power down box show red LED, I can't turn on from remote. If I reboot my box it never reboots and turn off, No LED light & I can use remote to turn on the box. Box is also stone cold this way. I have configured power button to do reboot.
                          Many thanks.
                          • superceleron
                            Editing a comment
                            1º well they m8 have it limited.. that is a boomer... :/
                            2º next version
                            3º that is a HW problem m8, my also is like that, nothing i can do about it
                          Originally posted by Sp00nman View Post
                          Morning all,
                          Thanks in advance.
                          Does anyone have any ideas on the above? Reverted to SCV 6 and home button is working again??
                          • superceleron
                            Editing a comment
                            That is weird since i dint touch anything on that side, and the home is working fine here.
