Originally posted by ReaperMan View Post
Heat stayed around 80°C ( with fan 67°C) and cpu 35- 40%. I had nothing running...... I gave up and rebooted the box.
Reap
Originally posted by deviltheturtle View Post
No, its not working too. i try sdcard method and usb cable method even i bought new 2.0 usb cable for this i am using usb 2.0 but nothing useful.
after install ota update via Local update function (zip file, dont need unzip)
@ Wyle,
If you root you should be able to > reboot to recovery with Reboot app. ( New Alfawise did not reboot, older one can) Then install your OTA SCV7A from SC Card. (Maybe extra USB powered cable will assist a successful reboot-Alfawise)
Don't want to root or can't reboot- Unplug power from box and insert paperclip in reset hole. Plug power in and continue to hold paperclip for 10(?) seconds and release. Should boot into recovery.Install > SCV7A zip and you should be good to go.
Give superceleron a bid wad of money/paypal. He might make time in his new busy schedule?
P.S. We can't see what your doing over there..so we try to offer the best help we can with little info.
Edit: P.P.S Thanks for all caps, makes it easier to read you.
@ almirus,
Thanks for the info. I have several vidcard/cpu heatsinks..somewhere. Hidden in some drawer or box along with a tube of thermal paste(old).
China Box running smooth with SCV7A. I've tried CyberGhost and exchanged my Purevpn apk for older version. Some back-ground services keep running till force closed.. Dropping CPU 30 % down to 2-3 %
Play services and Install helper services hang on too long?
I'm still testing for best results.
Originally posted by devang View PostFew things if someone can help to fix please....
1. TV don't switch to HDR mode while playing Youtube HDR video.
2. Setup & App buttons on original remote don't work.
3. After shutting down (either from bottom menu or power off from Reboot app) I can't turn on the box from remote. Need to reconnect the power supply to turn on.
@ superceleron
Many thanks for all the efforts. Could you please shed some light on my queries?
Originally posted by ReaperMan View Post@ Wyle,
If you root you should be able to > reboot to recovery with Reboot app. ....Then install your OTA SCV7A from SC Card....
My Original message was to SuperCeleron: "Can you make a version of your SCV7 ROM's that can be flashed with USB Method instead of OTA method, since OTA doesn't work for many people including ME".
i do know how to perform PAPERCLIP /ToOTHPICK method. I do not lack the knowledge. The BOX will not Boot into RECOVERY [HANGS]. "REboot" app doesn't work for me, either [Not ROOTED]. OTA apps doesn't work [HANGS after Reboot]
I am increasingly frustrated that everyone who has replied to my messages seems to ignore reading the problem and keep REPEATING the same advice.
How many times does a guy have to hear "PERFORM AN OTA UPDATE" when I write "I Can't get my BOX to do an OTA update"... before anyone will understand that NOT being to get the Box to do it IS the problem?
I have posted the same issue, as others have - about the BOX not being to perform OTA updates - and have gotten the "same" advice each time that you and
You may feel The CAPITALS in my posts are unnecessary but they demonstrate my frustration that all who reply seem to NOT read those Key words in their mIs-reading of my posts. Wihtout capitals, I don't know how else to point out what you guys seems to be ignoring.
Please STOP sending the Opposite answer to what my post have pointed out. I do appreciate the help - i do know how to perform PAPERCLIP /ToOTHPICK method. I do not lack the knowledge to upgrade my ROM's since I have done so almost a dozen times in the past year trying out different developers ROM's.
I do Lack the patience when people aren't reading and comprehending my posts...and offer unsolicited advice, often repetitive in it's misunderstanding... especially when it hasn't addressed the problem.Last edited by Wyle; 09 October 2017, 21:36.
Originally posted by neutester
Sounds like you power adapter might have gone bad...
superceleron Can you please make visible the remote button configurator app? Or else atleast tell me how to modify system files for changing remote button behaviors. Most importantly I want to set the green color app button or the mouse button to bring up the recent apps list. Also I'd like to configure the numbers to certain shortcuts. Please help.
Originally posted by LSHER View Post
Originally posted by ReaperMan View Post@ Ace310,
If you want to move files around manually, you will have to root your China Box.
I suggest Magisk v.14.2, you can then add a plugin to allow SD card R/W permissions.
Edit: Just a concern. The Box I bricked- I'm sure the SD card slot kept corrupting my card. If your card was not formatted FAT32, then maybe an issue to test out.
Originally posted by Wyle View Post
Reaperman & devang, I appreciate you re-stating what other are saying but my original message was addressed to SuperCeleron regarding a new package for his ROM's.
And i cant make now the IMG, i am slam with work...
There are currently 6511 users online. 2 members and 6509 guests.
