Originally posted by chenrp
maybe you moved the box a little bit while pressing reset to enter recovery
Poslano sa mog Mi-4c koristeći Tapatalk
deviltheturtle try this rom
flash it with usb burning tool
msc1 seem to have same hardware like yours and got it working
Is it just me or is there no way to boot into TWRP recovery other than manually via the reset button?
I tried to reboot into the TWRP recovery from within the (magisk-rooted) Android system first via the pre-installed Reboot app and then second via Terminal Emulator app ("su reboot recovery"). Both methods lead to a reboot but then the display stays black even though the status LED on the device is blue. Is this intentionally? Or are there any tricks to make this happen?
Originally posted by frokteab View PostIs it just me or is there no way to boot into TWRP recovery other than manually via the reset button?
Another way is to power the box from USB OTG cable and do reboot from app. Reboot works for me this way.
my license folder is: https://mega.nz/#!g4oQHKQY!S4FzGOt4O...fQbYJ_0YETUsws
don't forget to edit mac_ether.ini
replace "------" with last 6 digits of your mac. or you may change it to completely. (the first 6 digits are vendor id, if yours is different change them too)
superceleron ..Thanks for your prompt responses dude. It feels good to have contributed atleast this much to your next build. Awaiting SCV8 (probably with Oreo :P ).
P. s. - Sorry for kinda spam posting :P , I don't know how to comment to a post here from mobile.
Originally posted by incrovantilist View Postsuperceleron ..Thanks for your prompt responses dude. It feels good to have contributed atleast this much to your next build. Awaiting SCV8 (probably with Oreo :P ).
Originally posted by ReaperMan View Post
Edit: P.P.S Thanks for all caps, makes it easier to read you.
I'll chalk it up to poor translation or bad reading skills.
You keep telling me to reboot box and press pin in.,. when I'm writing you that the procedure doesn't work on this box - it gets stuck on boot screen and won't go into this "mode".
But thanks anyway.
There are currently 6516 users online. 2 members and 6514 guests.
