I bought a new 32gb/3gb ddr3 Alfawise H96 Pro Plus box from gearbest last month and was looking to put this custom ROM on it, however I read the thread below:
I'm afraid my box matches with his description of new boxes (i.e. i see android 7.1 written on back). Should i flash this ROM or i can expect troubles if I flash this ROM? wolfsstolz superceleron please advise?
superceleron I've installed RoMs earlier using USB Burning Tool (directly by connecting with USB male port), but they have "img" extension. Can you please help me how to do this using "zip"? As far as I can understand, you encourage people to use burning tool rather than SD card method. Am I missing something here?
superceleron I got confused after extracting SVC7A and finding files there, and made a similar assumption about SVC4. Can you please change the description in the first post to SVC4 (Extract Zip to Img) followed by SVC7...? I think it'll help unfortunates like me.
Also, applied SVC7 OTA from pen drive by selecting file in the app itself and reboot. Thanks a lot for the work, youtube 4k puts a smile on my face.
superceleron (and others): is it possible to show the cpu-temperature (soc-thermal) constantly in the upper status bar? (like battery-percentation for example)
Originally posted by tombraga View Postsuperceleron (and others): is it possible to show the cpu-temperature (soc-thermal) constantly in the upper status bar? (like battery-percentation for example)
but would like to have the cpu_temp shown in the statusbar, so i can look at it during watching a kodi film for example without leaving the kodi, only push the statusbar down, understand?
perhaps it is possible to include this in the next versions, superceleron ? (anda-lá)
Thank, yes i installed now cpu monitor, they have a widget which i could place on homescreen.
There are currently 4449 users online. 0 members and 4449 guests.
