Originally posted by tampametal View Postsuperceleron does this work with the banggood version of the H96 Pro+?
The current models retain the red standby led after a firmware update. The older models lose the red led after the first update. It only comes on when you shut down the box. Not tested on older box yet.
There are a lot of variants out there now.
I often see Chinese clones of Chinese products that were cloned from an original first generation device. It gets very confusing.Last edited by Modelman; 29 October 2017, 18:20.
Originally posted by Modelman View Post
Yes works on the Banggood current models.
superceleron I need a USB to USB cord to flash with USB TOOLS? My other boxes had USB to MICRO USB cord
Originally posted by tampametal View Postsuperceleron I need a USB to USB cord to flash with USB TOOLS? My other boxes had USB to MICRO USB cord
I heard people had issues with using a USB 3.0 to Flash ROM's but I had no problems!
Originally posted by Wyle View Post
YES - Sorry to butt in here but I bought one off **** recently, USB 3.0 CAble with USB A to USB A, it was 3 feet long and in a pretty blue for about $3 (US)... but you can also buy a basic one in BLACK color, for a LOT less.
Originally posted by ReaperMan View Post@ Ace310,
SD Card permissions is more for later use when copying and pasting files around manually inside Android/Kodi etc. Google want to ownyou your box.
Just checked xda and they have a newer version 2.1
I think superceleron has set selinux to permissive....no need for switcher version (I Believe?)
(NEW) v2.1 -for Magisk v14.2 (BETA)
http://www.mediafire.com/file/zv7r55...Magisk14.2.zip
http://uptobox.com/qb83vhiab9fl
Hey everyone. So I stay in China and want to buy and resell the H96 pro+ with 3G DDR3 32G to other foreigners here in China. I prefer Magisk as my rooting software as it makes for the easy installation of viper4android audio fx and Dolby atmos. Has anyone got magisk working on this device?So I'm completely looking at building a custom software environment using this custom ROM. How is the stability of it compared to the stock ROM?
Originally posted by Mandrake View PostHey everyone. So I stay in China and want to buy and resell the H96 pro+ with 3G DDR3 32G to other foreigners here in China. I prefer Magisk as my rooting software as it makes for the easy installation of viper4android audio fx and Dolby atmos. Has anyone got magisk working on this device?So I'm completely looking at building a custom software environment using this custom ROM. How is the stability of it compared to the stock ROM?
Stability of the Rom is good however I don't think the developer or its followers would endorse (support) people using it for financial gain. I suggest you stick with the stock rom and amend that to your requirements.
Originally posted by chenrp View Postmy friend got the new box from gearbest with only two usb ports soldered in.
the memory chips are different
before flashing V4 can anyone say for sure that this rom will work on the new box?
thanks!
There are currently 1379 users online. 0 members and 1379 guests.
