I want to disable the oc systemwide forever. How could i do that? I can use a kernel tool but there i only can disable the cpu oc.
Reflashed again and looking how it goes. I am now missing the midle portion of the launcher?!Last edited by TheRealDadBeard; 08 November 2017, 17:55.
hi, thank you for the great work.
i just burned v4 with burning tool and proceeded to flash the card to the device however it just seems to get stuck midway through the 'updating' screen. Any advice? thanks!
does anyone have a video link so i can see what should happen? i am pretty sure i have done everything correctly.Last edited by moley10; 08 November 2017, 23:26.
Originally posted by Alianato View Post
Try to use superceleron firmware, you should read previous posts, he created a test firmware for that purpose, then you need to enter recovery and install it via one of the various tools that allows you to install firmware
Originally posted by willy792003 View Post
I did but that's not the problem. The problem is I can't even flash anything. USB burning tool doesn't detect my box now. I plug in USB and holding the small pin doesn't work. I tried the short circuit method also doesn't work. I am running out of idea. superceleron or anyone, please help!
1) Without the power plugged in, with a pin, I press the reset button and let it pressed.
2) With the usb cable connected to the computer I connect the other end to the second usb port still keeping the reset button pressed
3) I release the reset button, normally I hear a sound of USB connected in the computer
4) I can pick whatever tool I want and flash the box
In these operations I never plug the power, I just use the usb for giving power to the box, my computer is providing the power through the usb port.
After flashing the box and boot, normally I connect the power and remove the usb cable
blueprintdk had two bricked boxes and apparently could solve the problem, perhaps he can help you, anyway I can tell you how I do it.
If not seeing means driver or maybe you have in wrong port... Some of these have 2 ports burriex in box and not cut out. Those ones also have it's ota port covered. 2 or 4 ports?
also make sure windows drivers installed world cup drivers are posted on tool section of amilogic thread.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Thanks for the advice m8. But I tried this a hundred times. No USB sound plugged in on my PC. Like I said, it doesn't detect my box! Any other method I can try to make my PC detect it? New USB driver maybe? I am on Win10 and updated to latest patch. Thanks
So you should know the USB port to use and the cable was working
Maybe you just used the SD Card method ...
Anyway, as the others say I advise you to check the drivers in the amlogic section in this forum
Originally posted by superceleron View PostUpdated 1º post with Blue PCB LPDDR3 IMG.
.From this message http://freaktab.com/forum/tv-player-...ead#post678040
Only Blue PCB is to confusing.
There are currently 2913 users online. 1 members and 2912 guests.
