Think i found a bug
I have the RBOX PRO 3g, all working sweetly, wifi, bluetooth etc.
I installed Super SU from play store after initial install yesterday and all was well, grants root access for apps i use.
Today, the usual message to update supersu came along and selected NORMAL as i always do, then reboot.
Since this, the box freezes after the music with superceleron bootlogo appears.
I can always reflash, but at least its a bug that can be mentioned and hopefully overcome.
I presume rom is already rooted? thus a conflict when i install SU?
Best wishesLast edited by Wingchundub; 23 May 2017, 09:54.
I am aware of boot up edit issue.
It was since i installed super su, it freezes of which i tested 4 times, leaving each boot for 10 minutes to be sure.
I feel it was i installing supersu that caused it to do so.
Since reflashed and no superuser installed and all is well again.
Thou i forgot about the loud sound on bootup haha
first few bootups scared the hell out of my Cats LOL .
you can disable the boot up video https://www.technologyhint.com/disab...ation-android/
if you disable the video you get 17 seconds of black screen . tested by editing the build.prop . just keep volume down at the start
can you add this: https://www.gizdev.com/viper4android...o-beats-audio/
and magisk into the next release?
Originally posted by messerchmidt View Postcan you add this: https://www.gizdev.com/viper4android...o-beats-audio/
magisk, i need to see how it works since i never use it!
There are currently 1369 users online. 1 members and 1368 guests.
