superceleron - Thanks for all your efforts. I am newbie here & recently got a Alfawise H96Pro+ hardware with 6.0 stock running. I do see yours is latest stock modded ones & based on posts here, I see it is good one to flash. As am newbie to this flashing stuff, how to use USB flashing for my model (any video links to my hardware)? also can we use SD card method for your modded image to flash the same on my hardware (I see its little easier as per the Utube videos)? Please help. Thanks in Advance.
Originally posted by Valek View Post "merci à lui"
Install firmware with a microSD card
STEP 1 (download and extract).
Download :
Burn Card Maker and firmware
Extract "TF.rar" and firmware in the same folder.
Now you get "Burn_Card_Maker.exe" and firmware file.
Rename le firmware update.img
Put a microSD card in your computer (on Windows) and go to the second step.
STEP 2 ("make" the microSD card)
Run "Burn_Car_Maker.exe"
The first time it's in chinese, click on the top lef menu, click on the second option, check "English" and put "OK".
Close and restart "Burn_Car_Maker.exe"
Chose disk: (Letter of your microSD card)
"YES" must be check 3 times for "To Partition and Format", "erase_flash" and "Reboot" (erase_bootloader must be uncheck).
Click on "Open" and chose firmware img.
Click on "Make", format the microSD card (default settings), after that the rom copy begin on the microSD card, when it's done you get a "Success" message.
STEP 3 (installation)
Now, insert the microSD card in the device (power supply unplug/off).
Let your TV on and the HDMI cable plugged.
With a paper clip or other, press the reset button and hold it (small hole under the box), in the same time plug the power supply on the Beelink GT1.
Originally posted by wwmoggy View PostOriginally posted by Valek View Post "merci à lui"
Download :
Originally posted by ppoon View PostI was returned a new H96pro+ back from the distributor due to power shut off issue. It is upgraded DDR4 ram with 7.1 rom and everything work fine now. I have tried several ways to flash the TMRP but all failed. Is there any different way to flash TMRP in 7.1? Please advise. Thanks.
Until now i dint found a twrp for 7, you need to wait for one of the twrp gurus fix it since the changes on recovery from 6 to 7 was a bit big and the old ways of doing it simple stop working!
There are currently 1599 users online. 0 members and 1599 guests.
