Originally posted by wwmoggy View Postit is rooted I have not test xposed . the built in wifi antenna is not the best
Xposed dont work, i mean theirs still no public droid 7 xposed, the dev of it is a bit missing in action!
And no this ones dont have vulkan, and to add to support for it, it needs to be amlogic doing it in the base sdk!
I will rls later today SCV2 but 32bits since its a lot more stable and cooler....
Why 64? i dont see anything that its better than 32, unless you have 4gb ram!
But yes i already added to the gt1... 32 and 64, but its still internal...
https://www.reddit.com/r/Monero/comm...ith_openclgpu/
https://www.reddit.com/r/Monero/comm...android_arm64/
Anyway, I've been able to run the 64bit code as-is, I just had to copy /system/bin/linker64 and a bunch of /system/lib64 from another device over, so the executables would load. So at this point it's nothing urgent. I'd like to try the 64bit libOpenCL, but so far it seems these GPUs aren't great for this task.
Originally posted by hyc View Post
I've been using them for cryptocurrency mining. The 64 bit miner is much faster than 32 bit.
Originally posted by wwmoggy View Postall backup and ready
btw added twrp to it
There are currently 1550 users online. 0 members and 1550 guests.
