    does samba server work in it
ID:	648785 replaced heat sink with one from E b ay .
      then raised box 1/2 inch of table and placed my note book fan on top sucking the heat out . idle temp nw 33 C a 6c drop and max temp 45 C 10c drop Click image for larger version  Name:	Picture 48.jpg Views:	1 Size:	76.0 KB ID:	648780
      Click image for larger version  Name:	Picture 51.jpg Views:	1 Size:	78.0 KB ID:	648781
        Any chance of getting a 64bit Android 7 onto Beelink GT1?
          Why 64? i dont see anything that its better than 32, unless you have 4gb ram!
          But yes i already added to the gt1... 32 and 64, but its still internal...
            I have dropped back to 6.1 SCV2 for now its runs cooler and at 32bit all my apps work . will wait for the 32bit android 7 before I switch again
              superceleron I know it has been mentioned in this thread that this ROM is for DDR3 variant, just querying to ensure if i can flash on my newly bought DDR4 box or not??
                I cant tell m8, i dont have a DDR4 box... it should work but im not 100% sure!
                  Well i should rls again a very very very beta build but this time 32bits... i think it a lot more stable and cooler than 64bits one... i dont see any gain on it for boxes with less than 4gb of ram!
                    Better a very very very beta build then a very very very very very very beta build
                      lol yes... well the tests are going ok... so lets see if i rls it early
                        will be sending some beer Wednesday
                          glad someone will lol
                            First of all, thank you for your hard work put into this project. May I ask how to know what exact model I have? I would like to try out this ROM but I don't know can I install it on my device?
                              Originally posted by mrdidit View Post
                              https://www.banggood.com/H96-Pro-Plu...ft-hotproducts
                              H96-Pro-Plus 3GB ram 16 gb rom --- DDR3 RAM yes you can install it . but I would wait for next improved version
                                Thank you for clarify. I need to tell you I waited just two days before opened it up and placed elsewhere the wifi antenna because of bad reception. So what you think do I want to wait for another version? One more question if I may ask. Is it rooted and is xposed working?
