Here are some things i've noted between firmwares when running Antutu benchmark. Dunno if this will help or matter any
H96 Pro+ 3g/32g DDR4
SCV1-GT1_Ultimate - Antut 39K score - good sound on benchmark
SCV1-BETA-A7.1-Alfawise.H96.Pro+ - 40K score - good sound on benchmark
SCV2-BETA-A7.1-Alfawise.H96.Pro+ - 41K score - crackling, hissing and buzzing sound on benchmark. Had my cats ears perk up
Hi superceleron, I have been using this new firmware since I got the box and it works smoothly. Thank you for your work! The only problem I met was that FTMC could not play certain 4k videos (no picture, only sound with amcodec turned off), and I fixed this by installing the latest kodi.
However, I noticed that this box's temp is pretty high (according to andboost app) - when playing 4k videos it could reach 90 degrees. I was wondering if such temp is acceptable for the long-term? Or should I use some external cooling system? Thanks!
Since I have flashed your other MM ROM I can not access recovery mode to flash this ROM. (power off,hold reset, plug usb to pc) Should I need to reboot TWRP? Or how to connect to PC? By the way why wee need to flash via pc if we have TWRP?
Edit
Now it is OK, need to plug it in directly not to the USB HUB.
First of all thanks for the ROM.
Finally a box / rom I can watch 4K videos DTS / DD via HDMI without any hassle.
Had not much time to test but FTMC crashing on some of my 1080P moovies however has no problem with the 4K ones.
I like you hasn't changed bootanimation.
The colours looks a little bit washed out or is it just me and there is no modification?
Edit
Dont worry Mediacodec plays both of them just fine!
Well i did have a video bootanimation... but since im not a video guy the ending of it make it look like the box crashed LOL so back to the old one!
Colors, dunno i dint touch it. but im so busy this last month that i dint use any box or FTMC to see any videos... no free time, i need to start to brake a little or else i dont enjoy my own work...
Originally posted by huch View PostThis rom working nice on Beelink gt1 ultimate ,only after I lost remote control,but all the problems with video stuttering is fixed now.Thank you Superceleron, do you plan to release for gt1 ultimate?
There are currently 1429 users online. 0 members and 1429 guests.
