Hi, I couldn't get the update started: I have SCV2 currently, I put the zip file in a USB drive, I go to the update app and select the file to local update, the app then shuts down the box but does not reboot by itself. I had to manually press the power key on the remote to turn it on again, but then the box just started the normal booting process without updating. Is there anything wrong in my process? Or could you please upload the img file as well so that I could use the USB flash method? Thank youLast edited by antonyzyl; 05 June 2017, 08:20.
the link is working http://freaktab.org/75f04d482ffead8b.
you can not install using flash method .
alternate download link https://mega.nz/#!sxo0TYxA!mF2RWcVK9...Iaeb5aXIYVnz_M
There are currently 1009 users online. 0 members and 1009 guests.
