Originally posted by Alianato View Post
Just bought H96 Pro plus from China so reading up while awaiting delivery. Generic box - 3GB/32GB DDR3 appears to be the max available. No DDR4 model or 64GB model available. Android 7.1. Specs does say it has AP6330 wifi and not the Q9377 as stated here (most sellers don't specify this at all). Does this mean I should stop reading any further? Is this the reason for some of the issues here? (I'll probably open it up to see which wifi chip is used).
BTW, is this true?
green motherboard - uses AP6330 wifi
blue motherboard - uses Q9377 wifiLast edited by mslim; 12 November 2017, 13:04.
Originally posted by mslim View PostJust bought H96 Pro plus from China so reading up while awaiting delivery. Generic box - 3GB/32GB DDR3 appears to be the max available. No DDR4 model or 64GB model available. Android 7.1. Specs does say it has AP6330 wifi and not the Q9377 as stated here (most sellers don't specify this at all). Does this mean I should stop reading any further? Is this the reason for some of the issues here? (I'll probably open it up to see which wifi chip is used).
BTW, is this true?
Hi, I am having trouble, My PC (windows 10) will not recognize my TV box, I have used the USB Burning tool on other boxes and I know how it works but with this box when I plug it into the PC, nothing happens, like nothing is plugged in, cable works on my other 2 boxes so I dont believe it is that, any ideas?
original green board is Q9377, and the blue board from the pics that i have seen are also Q9377...
original green board is Q9377, and the blue board from the pics that i have seen are also Q9377...Last edited by mslim; 13 November 2017, 02:34.
Originally posted by mcerk02 View PostHi, I am having trouble, My PC (windows 10) will not recognize my TV box, I have used the USB Burning tool on other boxes and I know how it works but with this box when I plug it into the PC, nothing happens, like nothing is plugged in, cable works on my other 2 boxes so I dont believe it is that, any ideas?
USB burning tool question ?
I flashed using Erase Flash (normal) and Erase Bootloader checked.
Is this the proper settings ?
When my box boots it displays the Superceleron Logo and appears to be ok and then it will display the Logo again and then fully start.
Is this normal or should I try to reflash using USB tool ?. I always flashed before using SD card.
Edit: got it. Used a toothpick for starting recovery
Originalpost:
Is it possible to get a hint of what I am doing wrong? I flash via burning tool twice because someone says it should solve the problem with not updating. This doesn't work. I already have v4 installed and can't update. If I allow it in the app the box just shut down.Last edited by Haematom; 17 November 2017, 18:27.
There are currently 1872 users online. 0 members and 1872 guests.
