Superceleron has done a wonderful job on creating a superfast rom that outperforms anything stock, so only minimal tweaks should be needed.
Can I make a suggestion. If there is going to be a V8 don't change anything just refine or bugfix. Adding or removing bits and pieces that people are requesting will probably create additional bugs. If no further revisions after V8 are going to be made then this could be counterproductive.
Superceleron has done a wonderful job on creating a superfast rom that outperforms anything stock, so only minimal tweaks should be needed.Last edited by Modelman; 26 November 2017, 18:37.
Originally posted by BringerOfRainX1 View PostWhen updating from SCV4 to SCV7A, am I right in saying you can't use USB burning tool? Can you update via USB stick rather than SD card?
Originally posted by Vaizen View Post
V7 installs through update app or TWRP. you can have the file on the device or USB flash drive. No need for flash tool.
I found some patch for gamepads with 0079-0011 id
can you add it to your rom?
https://github.com/spbnick/dragonris...ck_0011_driver
https://android.googlesource.com/kernel/msm/+/android-7.1.0_r0.2/drivers/hid/hid-dr.cLast edited by gogeta; 27 November 2017, 03:24.
Originally posted by superceleron View PostGuys im not going to promise anything.. add/remove i cant even remember the bugfixes i did!
Originally posted by Mandrake View Post
The only thing I'd suggest is fixing the Google app. When searching none of the links in the results are clickable. As a result I have to search from within chrome. Also the stock YouTube is the same. Also can't use the wireless mini keyboard to type into the search field,, have to use the on screen keyboard. As a result I uninstalled that and downloaded the version from play store. Also your Kodi media centre sometimes crashes. I'd agree don't add anything new, just streamline and fix bugs in v7a.
The "default" youtube app is like that since is the android tv version and on that one the air mouse dont work... that is is why i leave it uninstallable so the user can choose to the one they like!
FTMC crash.. hmm that is hard to tell, some bad addon can do that.... my kids use it everyday and rarely crashes!
Sorry to jump in like this ...
Have purchased H96 pro plus, 3/32. ZH01-S912 ... V3.0 (09/22/2017) green pcb, q201_9377, box last week. Aigale wifi, Samsung emmc, hynix ram.
Want to ask if one should "burn" GREEN PCB SCV4 IMG 7.1.2 and immediatelly after SCV7A OTA 7.1.2 (presume contains cumulative patches).
So, no reboot in between or any other action? Amlogic burned 2.0.8 is to be used. Havent tested yet if the device is recognizable.
Green should be your version but no guarantee that it will work (too many clones of this box at this point)
OK.
So normal reboot after v4 image (if even system update is an option for cumulative v7a). Was confused with changelog, especially for "now 64bit".
About clones, on some forum in my home country, four h96 pro plus purchased in last two weeks, all four different. One even blue one with lpddr3, other three have green pcb but different ram, emmc and/or wifi chip ... Should work since all wifi are in fact Atheros9377 based.
Will see during upcoming weekend. First need to gain factory rom if possible. Got mine from banggood.
Enviado do meu GT-N8000 através de Tapatalk
Hello guys,
sharing my experience with the box. I was running SCV1 flashed long time ago with sd card method, so what did I do?
- opened my box to confirm PCB (green)
- downloaded SCV4 IMG - tried 2 sd cards - not a way to flash via sd card method, always stuck on recovery
- bough usb A male to A male (box said that cannot be used to pc - pc connection) but still
- tried all the external 2 usb ports - no chance/discovery under USB burning tool
- opened box - tried the 2 usb hidden ports - and voila!
- One of the hidden USB port was the OTG one
- First flash was not OK
- Booted the box into recovery (with pin holding while powering on)
- flashed SCV4 img via burning tool
- flashed SCV7A via OTA (sd card -> local update)
Now everything is perfect.
Hope my info helps.
There are currently 1010 users online. 0 members and 1010 guests.
