nprev917
Installed HALauncher. For Non touch and bigscreen it's really great.
Mandrake
Did You maybe look into game files if they don;t have they own keylayout file? It would be probably generic one or close to it. Description of both games in Store says that they are compatible with game controllers and as Android is only partially supporting them out of the box, than they have to have their own layouts or settings for that.
superceleron
Will check it later. Maybe it can be made to look even better than HALauncher?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Mandrake
superceleron
Mandrake
superceleron
Using the opportunity that superceleron commented several last comments to ask if scv4-v7a is tested/tried on these new, so called wisdom, boards with 8 ram modules?
There are several topics where that question is raised, no definitive answer. That would be ZH01-S912-TVBOX-v3.0 (3GB hynix/micron ddr3 ram in 8 modules, samsung/sandisk emmc, aigale wifi).
nop that should be another problem... but i dont have any 4k streams to test.. but well i really dont have the time this month to touch in this H96 roms!
dangchui
Id I understand what You wrote, than You can flash OTA without loosing the app any other data. You don;t have to do Wipe Data/Factory Reset. I didn't do it and I don't have any problems.
Anyone have problem with turning off the Box with V7A? If I use Power Menu->Power Off the Box just hangs on Powering Off. Reboot works fine and turning off through Terminal (reboot -p) too.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
ok thanks i try this tomorow ch3mn3y but i have for this moment problem when If I use Power Menu->Power Off the Box just hangs on Powering Off but red light and when i take my remote control for power on nothing pass no action it s necessary to take off the power cable and retake on
if you have solution
There are currently 1845 users online. 0 members and 1845 guests.
