Hi! I'm using this wonderful ROM, but I have a problem with audio:
While media center, VLC, Prime video and other apps all do output 5.1 surround audio if present, and it arrives correctly to my Amplifier, Netflix app doesn't seem to let me choose 5.1 audio, even in titles that DO have 5.1 audio, such as, for example, the new star wars movies...
Anyone experiencing this? The thing is that since other apps do that, I don't think I have an hardware / system problem...
Help me please!
I am really hoping someone can help me and I am not pissing everyone off by asking a question if already answered in the 120 page thread.
After upgrading my WIFI will not enable at all and simply toggles itself back to the off position if I try to enable it. I seem to remember it worked at one time with anotehr 7.0 upgrade firmware but I can't find that firmware and I believe it was the one that automatically vanished after 24 hours. Green board with DDR4 and the ever so loved FN-link 8223A-SR.
Any help appreciated.
How do I force portrait view with this ROM? I've tried the set orientation apps and they don't work. Still stays in landscape view. The reason I ask is because Pluto TV has options for video on demand that are only viewable in portrait mode, but because the view is forced to landscape I'm unable to access those options in the app.
Originally posted by Mandrake View PostHow do I force portrait view with this ROM? I've tried the set orientation apps and they don't work. Still stays in landscape view. The reason I ask is because Pluto TV has options for video on demand that are only viewable in portrait mode, but because the view is forced to landscape I'm unable to access those options in the app.
Hi all
Newbee question
Once I ve updated into SCV4 , how to go in TWRP to perform the SV7 ota update ?
Does the following procedure works, because mine I ve still has a black screen on my samsung qled (resolution not supported) when I follow the procedure below.
- power off
- paperclip to insert in reset hole(near USB port
-power on
- Hold for 6-10 sec. and TWRP will boot up. Select > Install option to flash the OTA firmware from SD
is it correct way to activate TWRP?
I am french sorry for any spelling mistake
thanks evryone
Correct. You can use Update app as well, it will automatically boot the TWRP and flash the chosen .zip file.
However if You want to flash Root (MAGISK or SuperSU) after V7A, than its easier to boot to TWRP with the pin (paperclip) method.
Additionally it gives You a possibility to make backup of V4 before flashing V7A update. If anything bad happens (shouldn't), than You will be able to restore that backup (as long as TWRP will boot).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by matt59631 View PostI have a green pcb and after flashing scv4 everything seems fine but when I powere off the device it appears to shut down but the red light stays on the box (so it's in basically in sleep mode) and I can't turn it back on no buttons work on remote to get it back on I then upgraded to scv7 ota and flashed fine but still same problem is there any fix for this? my pcb is green what will happen if I try the blue scv4 .....I've flashed many different boxes so it's nothing im doing "wrong" and I've tried to reflash a few times any help would be appreciated thanks.
This is not a fix but a workaround, for me it's better then nothing, perhaps superceleron can fix this bug in v8
There are currently 2424 users online. 0 members and 2424 guests.
