Try with different USB port or cable.
Originally posted by tribalito View Postdangchui Buddy but why i need to choose this firm? Is better than AlfaWise H96 PRO+ 3/16Gb - 3/32Gb - 3/64Gb - SCV7A 7.1.2 (DDR3/DDR4 and 9377 Wifi Chipset)?
Second question. After that i need to flash update for OTA?or only this firm?is possible with sdcard?
Download SCV4 GREEN PCB IMG:- DOWNLOAD HERE GREEN PCB SCV4 IMG 7.1.2
- MD5: E17A5C3B8AAE2E5053BC3077E14F874F
superceleron
Could You tell me if there is any difference between Power Off option in Power Menu, and Power Off button on the NavBar?
Coz I cannot find why button power offs my Box fine and option in the Menu freezes it (it stops on "Powring Off" and only reset button or reconnecting the power cord helps)...
I'm just looking for a way to fix Menu Power Off ot get another button like this (e.g. as a Tile) and than I will be able to hide NavBar.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hi Guys. I am a mainframe Dev in South Africa so I'm not a technology noob. I am to android though. I am not sure what exactly to do with the 2 files I downloaded. I downloaded, for the green PCB files the SCV4 image and SCV7A OTA. I've made a list of steps I saw somewhere on the forum. I also list some questions. Would you be so kind as to assist please?
1. download scv4 blue
2. also download scv7a ota
3. After you get v4 booted up, Q: How do I get V4 booted up?
4. go to the update app Q: What update app is referred to here?
5. select the v7a img and update it
6. It should boot into TWRP, Q: How would I know if its in TWRP or not?
7. but if its like mine from BangGood you'll have to hold the reset button and force it to boot into recovery.
Ziquilix
A3. Flash it using USB Burning Tool and than connect power and it will boot by itself.
A4. You can go straight to TWRP and flash .zip manually or there is an app installed, which does it for You (meaning you select zip file within it and it reboots the Box to TWRP, which than flashes zip and automatically reboots back to Android).
A6. You will probably see TWRP logo. Howveer even if it will go straight to flashing, than if You know how TWRP looks than You will know that that's it.
If You don;t know thank it looks like this: http://i.imgur.com/DnoCrqh.png
However when flashing it will be something like this (of course this is not flashing, but restoring existing backup and here is TWRP with phone UI, tablet/Box is wider, but it will look almost the same): https://www.howtogeek.com/wp-content...e-process1.pngLast edited by ch3mn3y; 22 December 2017, 12:52.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 6679 users online. 2 members and 6677 guests.
