Originally posted by Dr.Pancho View Post
This firmware is not apropiate for our board.
Our board is CZ-S32-v6!!!!! (You have same board as me)
CZ-S32- This is your board code
V2.2 -This is your Board revision
V3- This is The firmware version
S912 This is your SOC (system on chip)
Look at the picture that's my board, check what revision your PCB is an try to find the appropriate stock firmware for it just in case you run in to problems stock rom is the better way to fix things that I know ofYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by nickgr View Post
I know, I didn't use the v2 v3 firmware but only the v6 onesYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by hcardoso483 View Post
The worse thing that can happen is the rom not to boot like it is not booting now it's a very Same simptom if you flash wrong firmware you can always go back by flashing stock, but I don't advice on that becouse I don't know if you are aware of the different methods to flash firmware in case of trouble
actually by flashing a rom the kernel gets overwritten it does erase everything but not the bootloader if you choose not to, kernel and bootloader are 2 different things and I think you know that but you got a bit confused, try doing this way
1 Install your stock firmware
2 boot to twrp with the sdcard (do you know how to boot to recovery from the sdcard?) Open scv7.zip in WinZip and extract recovery.img copy that to the root of the sdcard get the sdcard in the box tray press and hold the reset button plug power hold it untill you see TWRP booting logo you will see the H96 logo first then after recovery boot make a backup of the boot partition (that's the kernel)
3 flash your scv4.img with the USB burning tool
4 before you do the first boot go to twrp and restore the boot partition you backed up early reboot, now it should pass the boot logo and start booting if not that's becouse your model is a newer one and there is no support for it yet but I belebel if you do this properly it will work
Originally posted by superceleron View PostHi guys/girls, sorry for the lack of updates, but really dont have to much free time this days to do my custom rom work, if anything changes i will update my roms if not...
Thanks m8 you're the only one that can actually do something, we only try to costomize your custom work, LoL, "Esperemos que vá dando resultado, até agora algumas coisas que tenho visto é em matéria de kernel e com o de fábrica vai dando para por a tua rom a funcionar que de longe é muito melhor (penso que nem seria necessário referir este ponto) quando tiveres tempo será sempre bem vindo e bem apreciado a tal actualização, fica bem..."
i replace the internal antenna with an external one and i am getting 2.4Ghz wifi connection.
before the replacement i connected to the 5Ghz connection.
i don't have an option to choose prefered network (5GHZ or 2.4Ghz).
i have root...
how can i choose or see all the 5GHZ connections?
is there an option that the external antenna is 2.4Ghz only?
superceleron Hi I want to ask you a question I have the S912 2GB/16GB version 4 Usb ports with rounded corners box and a blue light all around
Can I flash you rom? I have and another box ( Beelink GT! Ultimate ) and I am running your Normal Android version with zero problems
Thanks in advance
I installed SCV7A immediately after SCV4 on my green board Banggood CZ-S32-V2.2/ 3+32/9377 DDR3- no problem - then tried to install Magisk 16.0 thru trwp but got errors. Couple days later tried Beta Magisk 16.7 thru twrp with nothing corrected from 1st attempt with 16.0. Installed like a charm with root indicated by JoeyKrim's Root Checker. On the integrity check the cts profile false and the 2nd one is green (true) so I have to correct cts profile but it does seem like everything is working OK (haven't given it a good work out yet though).
Originally posted by McGiles View PostI installed SCV7A immediately after SCV4 on my green board Banggood CZ-S32-V2.2/ 3+32/9377 DDR3- no problem - then tried to install Magisk 16.0 thru trwp but got errors. Couple days later tried Beta Magisk 16.7 thru twrp with nothing corrected from 1st attempt with 16.0. Installed like a charm with root indicated by JoeyKrim's Root Checker. On the integrity check the cts profile false and the 2nd one is green (true) so I have to correct cts profile but it does seem like everything is working OK (haven't given it a good work out yet though).
Originally posted by lyubodelev View PostI have never heard about separate antennas for 2,4 and 5 GHz...
There are currently 3555 users online. 0 members and 3555 guests.
