Originally posted by drakman View PostI made the cable around 20cm long. The good news is that the box is connected on USB burning tool v2.0.8. 4
The bad news is that I already have tested 4 different images without success, It stuck at 9% with the message UBOOT/Partition_aml_dtb/Verify Partition/Error result. Any help?
Here's the mega-link to a vast collection of S912-ROMs - you could have found it in many posts on the first page of this thread!
Thanks Momo03. I tried a couple of ROMS until now but the results is the same.
Always get this f.... error at 9%..
I believe that lyubodelev has right. There is not solution of this error.
I think that will throw the box out of the window until tomorrow..
Btw thank a lot for your help and for your time all of you.
The box is dead..RIP
Originally posted by djthomasgee View Post
Ive ordered a new power supply and try again when it's arrived.
Now sometimes when I enter into TWRP the Box strucks on the TWRP logo. Then I took of the power supply wait 5 minutes and mostly I can enter TWRP.
.. Really strange.
I can enter to TWRP but when I change language to german on "welcome screen" of TWRP then twrk doesnt start again and I get a black screen.
Today the new power supply arrived. .. no change. Ive installed scv4a agan but the box stucks again at the freaktab boot logo.
Originally posted by Rasbi View PostIt is not possible to change the background. Not possible to use a colour or picture. It shows only the ugly default background (wallpaper).
I suggest trying ,y mod, if you want customisation options and have ATV without being confined to leanback launcher and Google junk.
Originally posted by X92-2GB View Post
It's part of ATV, so no background wallpaper change can be done on stock ATV.
What is y mod? Where can i find this tool?
you should check my posts, it should be the most recent.
Performance of this rom is good. But now the next problem. The weos classic launcher force close, no chance to do anything. Power off, shutdown, disconnection of power supplx, nothing helps. Box seems to be good but the roms are buggy. I will switch to an Amazon Fire Tv. Not rootable, but its working flawless.
Hello,
I have a H96 Pro+ 3/32 (S32-V6, blue) with android 7.1.2 stock ROM.
I installed the SCV4 ROM with sd card method without any problem (without erasing the bootloader, as I was on stock FW 7.1.2).
Thanks for sharing. I was on OpenGL ES 3.0 and now it is 3.2.
But, when I use TWRP for installing SCV7A zip file, everything is Ok except that I have a red error message:
Code:... - Wiping cache ... Installation successful. script succeeded : result was [Installation successful. [COLOR=#FF0000]E:unknown command [[][/COLOR] One or more zip requested a cache wipe -- Wiping cache now. ... ...done
2) Another thing, using KODI, AC3 5.1 passthru is working with SPDIF but not thru HDMI ?
3) The provided Reboot/Shutdown software doesn't work for me (ie shutdown) ?
4) Can I install Magisk 17.1 with TWRP ?
Thx for u help.Last edited by jcplu; 16 September 2018, 12:43.
There are currently 1696 users online. 0 members and 1696 guests.
