Well i can not tell about version but Superceleron ROM green PCB works without WiFi - BT and Ethernet.
superceleron is it possible to add in these ROMS drivers for other wifi chips like 6255 ?
Is it very difficult ?
I ask this because many users have other WiFi chipsets and a multi chip ROM would be very helpful !
Or if there is a way to add these drivers as a seperate zip file and install it through TWRP maybe?
Hi
Am not to sure which box I have as I bought it broke for a few off ****. I finally managed to get it working again so I thought I would give this from a try as don't like the default setup on it . Anyway when I try to install this using usb burning tool it just stops after a few seconds and comes up with an error. I thought it might be the box but I managed to install a normal from using this tool.
h96 pro+ Mbox
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
h96 pro+ Mbox
Thanks anyway mate saved from sitting there for days trying to install this
There are currently 2224 users online. 1 members and 2223 guests.
