I really don't understand the hoopla about peeps trying to get wide vine L1 on non certified boxes. This rom is not made for L1 boxes, so why change the finger print?
I chose to change mine so I can use Sony Bravia apps. Unfortunately Crackle sucks just as bad as YouTube Red and Hulu/Netflix so why pay for something that you can get for free elsewhere.- I think the best fingerprint now is the Samsung Note S, you get some pretty nifty freebies, like Samsung Kindle, Samsung Tubi, Samsung Tablet Peel remote, which is superior to the pay for on Google play. Also adding a lean back entry in the permissions tablet.xml allows a semi lean back option to run all but a few lean back apps without messing up phone / tablet compatibility. You just need to maintain Web view and remove chrome browser.
Originally posted by superceleron View PostGuys this box will never have L1, ever... its not like that wedevine works.
About fingeprint yes is nice it make more apps available on store for you, but i do not do it in my roms... that is a user choice!
but still it is a great box!
just waiting for ROM update...
Thanks for the firmware SuperCeleron!
I have noticed a big bug with the GREEN PCB:
When I tried to add an account by "Google Play" and want to type my email address with my Logitech mouse there the screen keyboard doesn't never appears although the "screen keyboard" is "enabled" in the settings!
Hello Superceleron there s now 5 MONTH in FRANCE For My CANAL Apk it s necessary to have WINDEVINE L1 And with this ROM there s WINDEVINE L3
your ROM is on ROM NEXUS IS it possible to repacK firmware with an other model
one people says there s technic with MAGISK and module magisk HIDE
Magiskhide props config to change the H96 fingerprint to that of a certified device for example FIRESTICK TV
or OTHER and magiskhide props config modules downloaded from within magisk manager,
Originally posted by dangchui View PostHello Superceleron there s now 5 MONTH in FRANCE For My CANAL Apk it s necessary to have WINDEVINE L1 And with this ROM there s WINDEVINE L3
I installed a live version of a bundled zip of Sony Music (which updates via play store), and a rock solid stable version of V4A, that don't mess with DTS output with HBO Go and others that pass DTS.
I just use a finger print to download hidden apps for Sony and Samsung on play store, and leave it be, as L1 wide vine is not and will not be a patch to install. Read up, none of our boxes have L1, and it is a factory install in a hidden partition, that cannot be setup on boxes that never had it.
There are currently 3533 users online. 0 members and 3533 guests.
