Hi, Just installed this firmware. In Youtube, no search function is available (the search and other buttons are greyed out). Any idea why?Last edited by tranceinsane; 17 November 2018, 11:17.
Hi. I have h96 pro plus and i switched to this great rom. Wow its really great. Thanks a lot for the great job.
So now i have a little problem. I have the box modded with a cooling fan powered by one usb port.
The problem now is that when the box goes in standby from cec the usb ports keep having power and the cooling fan never stops.
Is there any way to change that and the usb power down on standby mode?
Originally posted by tranceinsane View PostDid the bad thing and updated the inbuilt Youtube application, now it crashes and does not start.. reinstalled it a couple of times, but crashing remains, no way to start the application. Any solution for this?
-2.OG YouTube,
-3.YouTube for Android TV,
-4.YouTube Vanced,
-5.NewPipe.
@ tranceinsane,- Did you try to clear data from Original Youtube app/reboot before upgrade?
- Might have to go into TWRP >> Clear cache/Dalvik (Don't WIPE data). Sound like you have some corrupt data(it happens).
Originally posted by ReaperMan View Post@ tranceinsane,- Did you try to clear data from Original Youtube app/reboot before upgrade?
So I love this ROM. However I have an app that streams my satellite service online, however when i try to stream from the app or even the satellite service's website, they block the steam because the TV's box isn't Google certified. I'm running SCv7a for the blue PCB. Any way to get my device Google certified or to fake Google certification in order to use my satellite service online?Last edited by Mandrake; 08 December 2018, 06:27.
Originally posted by Mandrake View PostSo I love this ROM. However I have an app that streams my satellite service online, however when i try to stream from the app or even the satellite service's website, they block the steam because the TV's box isn't Google certified. I'm running SCv7a for the blue PCB. Any way to get my device Google certified or to fake Google certification in order to use my satellite service online?
Can you tell me which application you use for streaming the satellite to your network?
There are currently 1742 users online. 0 members and 1742 guests.
