Originally posted by aus View PostHi Alianto,
My own situation is that I use a learning capable airmouse, I had to copy the red button command of the original remote. The air mouse is very responsive on all actions but I do have to press the on/off button twice to restart,
Aus
let me recap,
1) when you turn off the box via command or app it goes into a sleep state with a red light on
2) in this state it does not respond to original remote
3) however if you press the air mouse (two times) it will turn on the box
is this right?
Originally posted by Mandrake View Post
Just change the power button allocation in settings from sleep to power off. This worked for me.
update: no, it didn't work, apparently this setting was ignored in my box, perhaps there is an entry in build.prop that fixes this issueLast edited by Alianato; 02 March 2018, 19:46.
Lot more reading for you....
You will find all answers all over freaktab no need to report.
.zip is done thru update backup if its an update. don't extract
If a .zip is a .img us burning tool. extract
Ask questions in threads people will answer they are a friendly lot but also have other things to do, Patience
Search first
hello friends, I have successfully flashed SCV1 burn to card and then installed on SCV4a using the same procedure, with working TWRP. My question where can I find the SCV4b, SCV5, SCV6 and SCV7 OTA. SCV7A is available. Thank you
Edit: I have installed the ATV version, what's the difference between the two versions offered here, have I skipped something? Thank youLast edited by Rmaier14; 04 March 2018, 08:17.
Originally posted by ReaperMan View Post@Rmaier14,
You only need SCV7A OTA after flashing SCV4(green or blue). SCV1 is based on Android 6(x32) and SCV4 is based on Android 7(x64)
Is there a chance for an update? I have some serious bugs with 7A. WiFi is not stable and Media files sometimes get corrupted or subs out of sync. I have tried several things and also did a factory reset-clean install but problems still there. I dont wanna imagine the scenario that a media box used for less than 20days is starting to die like that.
There are currently 2935 users online. 3 members and 2932 guests.
