from where I can download MAGISK?
I just installed it using the usb burning tool, then put the OTA on a usb drive and flashed it, no issues at all, super straight forward and seems to work better than then stock image that came with my Generic h96Pro Plus
NOTE: needed to add the magic root thingie in able to be able to actually use the reboot and some other functions
Way to goLast edited by thewebexpert; 10 February 2018, 21:01.
Originally posted by ch3mn3y View PostDon't think so. Kernel would have to be compiled with drivers for the dongle.
hi guys, sorry to ask a bit of a dumb question - but I'd like to know how to update to the V7 OTA update which is on the front page?
I downloaded the V4 img as it was a single image file, and installed onto my H96 Pro+ via USB Burning Tool. It installed no probs. I would have done the V7A but noticed there was multiple files so wasn't sure how to properly burn it straight onto the device? Once loaded, I tried to do OTA update but it came up with an error "Check Failed! Check Your OTA Server Agent".
I have copied the V7A download onto an SD Card - do I install from an app within the device?
Originally posted by ptyson View Posthi guys, sorry to ask a bit of a dumb question - but I'd like to know how to update to the V7 OTA update which is on the front page?
@ kwabh,
I think your are flashing your box with the wrong firmware. H96 pro is a different hardware China Box.
Try this forum: http://freaktab.com/forum/tv-player-...fi-gig-lan-bt4
Possible links to newer firmware...research and use at your own risk...
There are currently 4117 users online. 3 members and 4114 guests.
