Top tab of Freaktab web page....Freaktab Media Center :
any way to use the superceleron firmware but with the stock homescreen? I like the improvements but is it possible to use the stock homescreen with kodi as main large icon as well?
also how do you add more icons to the superceleron screen?
Not sure if this would help anyone, but I had a rather weired situation. My unit works fine but I couldn't OTA update it. I could enter the update app and select the proper firmware, but after the unit restarts it would again enter the normal system, not the restore mode, which basically prohibits the update process from starting.
My solution is to manually enter the restore mode by powering up the unit while pushing the reset button. In the restore mode one can OTA update the unit by selecting the correct firmware.
There are currently 986 users online. 0 members and 986 guests.
