please help :| anyone?
superceleron i find this rom very unstable, is it because of overclock? sometimes i get image artifacts other times i get pink layers in screen and i get constant program stop responding (google services, google play, etc etc). am i doing something wrong? how can i disable overclock?
No problems like that with me. However I use it only with FullHD capable TV. Maybe flash MAGISk (if You don;t have it yet) and than use Kernel Adiutor (or similar app) to lower CPU and GPU frequencies (should be supported)?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostNo problems like that with me. However I use it only with FullHD capable TV. Maybe flash MAGISk (if You don;t have it yet) and than use Kernel Adiutor (or similar app) to lower CPU and GPU frequencies (should be supported)?
I have blue one (S32-V6).
Only problem I found was reboot when I was copying large files (USB->Internal). But I believe I have to weak charger (low amperage). However it's fine for now, so I'm not looking for better one.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by hfmls View Postsuperceleron i find this rom very unstable, is it because of overclock? sometimes i get image artifacts other times i get pink layers in screen and i get constant program stop responding (google services, google play, etc etc). am i doing something wrong? how can i disable overclock?
Just installed SCV7A on my 3gb/32gb blue PCB box, it's working great! Thank you for all the hard work you've put into this rom. A couple of questions that may not be specific to this box...
1. Is there any way to install the standard youtube app instead of the AndroidTV version? I really hate the interface of the latter, and it keeps bugging me to sign into my google account each time I launch the app. On my older Mini M8S II, it came with the standard youtube app. Should I just search for the apk online, or is there a way to trick Play Store into giving me the standard youtube app?
2. Is it 100% true that youtube doesn't support any surround sound formats? I do see many trailers and demo videos for DTS-HD MA and DD5.1 but my AVR (denon S710W) always says stereo when I play them back. Interestingly when I play some of these youtube videos using my original PS4 on the same AVR, they do play back with the correct audio format. I did confirm that through Kodi I can play surround sound formats through the box.
TIA
A1. I use iYTBP MAGISK module for normal YT app. You cannot update it (as it will break iYTBP mods), but it gives You some features -background playback (app thinks that YT Red is enabled) and force resolution (up to 4K). Very useful.
A2. Yep. YouTube (as YouTube, not just Android app) doesn't support. Kodi just forces stereo sound to all 5.1 speakers, but it's still stereo sound, not 5.1 one. That's just limitation of YT service, so if it's not possible than app doesn't have that option available.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Thanks for the quick response. For A1 I actually found that the ATV Youtube comes installed with the ROM and I was able to uninstall it, then grab the normal version from play store. As for the extra Magisk version features I know that background play can be done with normal app+xposed, but not sure about force 4k. I don't have a 4k display so it's not critical in any case. Thanks for confirming A2.
This rom works well for me. Thank you.
I did have one small issue with it though. I did flash this because I wanted a non-rooted andoid, since I wanted to run the Canal Digital Go app on it.
On the standard 6.0 and 7.1.1 rom it wouldnt run, just showing a message that it wont run on rooted devices.
But with this rom (SCV4 + V7A OTA update), the app still did detect the device as being rooted and refused to work.
Ironically, I then did root it using Magisk 15.3 and after this the app happily runs without knowing its rooted.
Hello all, ive had a major issue with green board s32-v3(ddr4) it just wouldnt be found by pc either way flashed q9377-ota-S912-20170808 then used twrp to flash scv7a , its worked great ill let you know as i progress. big thanks to superceleron and ch3mn3y even though they hadnt spoke to me (this is first post) one question how do rockchip stop keyboard arrows interacting with the on screen keyboard etcLast edited by Billy141; 28 January 2018, 15:41.
There are currently 4093 users online. 0 members and 4093 guests.
