@tombraga
Die Serie lief live im TV, gestreamt mit dem VU+ PVR PLUGIN und eine Enigma2 Box.
(Stand übrigens auch in meinem Posting.)
Und die Temperatur stellst du um, in dem du KODI auf Deutsch umstellst und die REGION(!) auf Deutschland.
Die Gebrauchtwagenprofis gibts auf http://www.dmax.de/programme/die-gebrauchtwagen-profis/videos/die-gebrauchtwagen-profis-ford-f-1/
You can change the Temperature Display from Fahrenheit to Celsius via the REGION option in the settings.
Set it to Germany and voila...Last edited by DOMin8or; 03 October 2017, 16:52.
here the link of the tutorial https://www.youtube.com/watch?v=lmlZOqmrimg
@tombraga Thanks for the link. I don`t know that DMAX plugins are working again. In the last year, RTL and DMAX plugins has got some problems and they are wont working.
for more conversation, please PM me. This forum threat is about H96 Box and for guys they are searching infos about the box. it is very unuseful to read some uninteresting things. :-)Last edited by DOMin8or; 03 October 2017, 17:21.
Originally posted by DOMin8or View Post@tombraga Thanks for the link. I don`t know that DMAX plugins are working again. In the last year, RTL and DMAX plugins has got some problems and they are wont working.
A few questions here as i can't get the pc nor the sd flashing method.
1.if i flash via usb tool...should i use usb and power adapter at the same time in order for the pc to recognize my box?
2. If i use bootable sd card...with v4 img...i inserted the sd but the device won't boot from it...?
Originally posted by chenrp View PostA few questions here as i can't get the pc nor the sd flashing method.
Hi everyone! Since I'm a newby (but not in android flashing and modding) can someone confirm a SCV rom flashing from stock 7.1?
1. flash SCV4-A7.1.2-x64-Alfawise.H96.ProPlus (via SD card method)
2. flash OTA-SCV6-A7.1.2-x64-Alfawise.H96.ProPlus (via TWRP flashing)
Thank you in advance! I don't want to brick my device cuz it's brand new cuz I'm a specialist in bricking
Originally posted by ReaperMan View Post@ Ikbfreak,
I highly suggest:
1. flash SCV4-A7.1.2-x64-Alfawise.H96.ProPlus(via USB Burn Tool )
Read through the forums and see quite a few bricks from SD card method.(Might work...or might not)
I read through whole thread. I really did. Will try as mentioned before and see how it goes.
There are currently 1904 users online. 2 members and 1902 guests.
