In the next build it will be unrooted then you guys can install supersu or magisk by twrp as your linking.
Originally posted by Belyakov View Post
In the next build it will be unrooted then you guys can install supersu or magisk by twrp as your linking.Last edited by superceleron; 28 July 2017, 03:53.
Dont do it.. that is why i installed a mooded supersu app....
Greatz to hear that SC4 is in progress.
Thanks again for your hard works. Appreciated.
Originally posted by Belyakov View PostHey guys, i have an H96 pro plus 3 gb of ram and 32 of internal storage, but it's not an alfawise box, the alfawise logo it's not present on the box, will this rom works on my box?
I bought my box off ****... it was advertised as H96 PRO+ 3G+32G (DDR3).
Dont do it.. that is why i installed a moded supersu app....
Enviado desde mi ONEPLUS A3000 mediante Tapatalk
my tv-box arrived about 3 weeks ago and came already with the nougat version. Is there any advantage to change to the beta-version rom from here?
generally it´s working fine, i shut down or restart with the icon and not with control
but sometimes the box is freezing, for example when i am looking my sat channels with the sat-ip app (tivizen), but also when i am connected to some german mediathek channels like ARD - ZDF a.s.o.
Is this freezing a problem of the rom? or the players of the apps? or some other hardware problem of the box?
i am connected with ethernet cable and the speed is good (about 95 Mbs)
superceleron - what is your opinion about the freezing?
here some infos about the settings
this is my drm-info
This is my first post on this forum, so - hello!
Thanks so much superceleron . I came to this forum because I could not get my H96 Pro+ DDR4 (generic/unbranded - no Alfawise logo) working 100% with any ROM. Stock and modded 6.0.1 ROM had the screen-too-dark issue in YouTube and Netflix (I believe this is caused by wrong color space? 16-235 not 0-255.) That was fixed in stock 7.1.1, but then that ROM had new problems: completely insecure Root with no SuperSU/SuperUser possible, no XPosed possible, and other root-related issues - like Tasker reporting no Root features.
I came here to write a long post asking how to fix the screen-dark issue because I thought I couldn't use any of these ROMs on my DDR4 box. But then I did a bit more reading, saw maybe it might work.. and it does! One suggestion: remove the "DDR3 only" label? It really seems to work fine on DDR4 boxes!
In case it is helpful for anyone coming after me, this is a confirmation that the following steps worked fine on my H96 Pro+ 3GB/32GB DDR4 Q9377 box:- First I re-installed Stock 7.1.1 ROM as I had a custom ROM (XnetfoX eXtreme 6.0.1) installed and wanted to install SCV2 from a vanilla starting point.
- I flashed SVC2 using SD Card with Burn Card Maker 2.02 - ROM renamed to update.img, all boxes ticked except Erase Bootloader unticked, then boot H96 with reset button held down
- Booted, did initial config, all fine; added my Bluetooth mini trackpad/keypad no problems
- Copied the SVC3 OTA ZIP to an SDCard, put it in H96 Pro+, ran Update app: chose Local Update; selected the zip file; chose Wipe Data; install ran fine.
- Booted, did initial config again, all fine
- Did SuperSU update - first time I tried it said SU was "locked", but after one more reboot it updated fine.
More good news: I was able to update Netflix! The OP said it was broken, but I thought I would try anyway because I knew it worked OK on the stock 7.1.1 ROM. I used Aptoide to update it to 5.3.0 build 19261, which is the newest build by date. And so far it seems absolutely fine - I've only watched a few minutes of a couple of programs, but haven't found any issues, even after multiple reboots.
The ROM feels very fast - definitely quicker than the stock ROMs (both 6.0 and 7.1) when loading and switching apps. I was always a little disappointed that the stock H96 didn't seem as responsive as I felt an 8-core/3GB box should be. Now it is!
I didn't manage to get XPosed Framework installed yet. I got the Installer on there and downloaded the Framework which rebooted to TWRP for installation, but then when I tried to install the ZIP I got a bunch of installer errors. That's not surprising as the 7.1.1 framework is still early beta. I might try to investigate it in more detail later.
Thanks again for all the amazing work on this!Last edited by TheBloke; 02 August 2017, 09:19.
Today i tried to install SCV2 with burn card maker 2.0.2, all the process of preparation of the SD card was sucesfull, but i got this error trying to install, pressed the reset button, connect the power cable to the box hold the reset button for a few seconds and nothing happened, only this Android logo with an X on it
Originally posted by superceleron View Postis freezing because the stock rom is hot.. real hot..
I recommend you open some holes in the box.
i thought you would tell me to try your rom instead the original rom
Originally posted by Belyakov View PostToday i tried to install SCV2 with burn card maker 2.0.2, all the process of preparation of the SD card was sucesfull, but i got this error trying to install, pressed the reset button, connect the power cable to the box hold the reset button for a few seconds and nothing happened, only this Android logo with an X on it
Anyway I think now that this has happened, you need to try burning again using the USB burning software (which is superceleron's recommended method anyway). You need a USB A to USB A cable to do it.
Originally posted by TheBloke View PostYou need a USB A to USB A cable to do it.
is this correct?
There are currently 2415 users online. 0 members and 2415 guests.
