Originally posted by yudi.15 View PostPlease help me out... I successfully have installed this rom 3 times but everytime when I turn on the device, it stucks itself of the bootloader screen for quite long take it as for 30 minutes and doesn't go any further
Sharing my fanless cooling project- Pry "heatsink" of cpu (with care!)
- Put a nice large hole in cap above cpu
- Make a "heatpipe" to transder heat to outside. (Used copper shims and kafuter k-5204k as thermal glue)
- Use thermal grease, no glue on top for connecting nice large heatsink.
- Put 90x90x18mm heatsink on top.
Didn't connect it permanenty, but first tests just laying the heatsink in top of "heatpipe" showed a about 20 degrees ambient delta (celcius) with a cpu burner test running.
Looking for a slightly bigger heatsink with thick base, and lots of fin's.
Using a smaller heatsink 80x80x7mm results in about 5 degrees higher.
Fyi, while testing, just having the printed circuit on table, there where no components other then cpu which felt hot.
No need to cool anything if cpu heat gets out easy.
Thinking of:- isolating the "heatpipe" preventing heating up the inner part.
- isolating the bottomside heatsink and case, preventing heating up the case/inner parts.
Regards,
Arjan
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
There are currently 1564 users online. 1 members and 1563 guests.
