    Originally posted by Wingchundub View Post
    All done.
    No more running to soundbar remote to turn volume down lol.
    Issue i have is with the Status bar.
    I go into setting and dispaly, then click statusbar adn turn it on, it appears, but soon as i press on down drop arrows, i can not bring it back up like i could in scv1, by simply dragging up.
    I have to go back to settings and turn it on again.
    Just to remind you, firmware is install on my r-box pro 3g, as may get different results on another box.
    Hello,
    I have the same issue on my h96 pro plus as anybody solved this?
    Also I would like to ask hot to unroot as the latest netflix app are not compatible with rooting.
    Also I think many app (including Chrome) are downloaded in the Android TV version and it is annoying because you cannot drag the pages with the mouse.
    Thanks to anyone that will help
      Does this come.with android tv launcher thingy or is there away I can get?
      I'm still using [ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3A-ATV Version (DDR3 ONLY)
      which works fine for an but would like to try this rom
        In my experience leanback launcher (Android TV Launcher) chrashes on this ROM. It's easily found on the web.
          guys i think i have pro + 3/32 DDR4 version, is this the only custom rom available 4 that version?
          i'm having a lot of problem with wifi and i need to reinstall or reset..
          any suggestions?
            No, this is for the DDR3 box: The Debloated firmware is for the DDR4 box.
              were can i get this debloated firmware to try it out?
              ps. sorry celeron god boss i have to try something else, because i'm really needing the wifi
                We all have to do what we think is best for our boxes
                  you say this is for the DDR3 boxes only but I've used in on my DDR4 box and it works fine, currently testing latest 7.1 firmware update from chinagadget review site.
                    I made new one ill post public soon. But supers roms are kinda hard to beat he fixes thongs that I have no clue about. Mines just modified stock nothing special.
                      Maybe, but dont be modest because you saved my day. With your rom the wifi started working on the my girfriends house router that it didnt work before..
                      Not sure if its because why.. but superceleron one was not working.. maybe android version?
                      My box came with stock 7.1.. but also wifi was not working with both my router
                      Superceleron you think this is problably a driver diff our issue with Android 7.1?
                        it problably has different chipset for the wifi so ya driver issue this one is for the 9377 wifi chipset
                          Beats audio, maybe!
                          magisk, i need to see how it works since i never use it!
                          It would be great if you can add magisk in the next release .
                            I see you are on NOS ISP... easy fix, just go to the router and change the channel to a lower one, and in the box enable the "dev mode" and then enable "Legacy DHCP" or in portuguese "DHCP Antigo"
                            And you see it will start working... sh*t NOS routers....
                              nice portuguese efort heheh
                              thks superceleron will try it out.. Legacy DCHP in on wifi options right?
                              i already tried to choose lower channels and changed encryptions method etc etc.. sh**t router on the spot!
                                you need 1ยบ to enable dev options and then is inside it, see in the youtube how to enable it it, is super easy!
