Any planned updates to this ROM? I welcome any NAS server app like scv3 (android 6.0) had.!
SC - "SCV3 + 7.1.1" is working great on my **** "h96 pro+ 3+32g" box Idle temps aren‘t bad with stock box, no fan and 3/16" rubber feet hot glued to underside of box for passive cooling. Sure it gets slightly warm but only has issues around 3rd hour of TV streaming...but that may be due to internet congestion.
Been using SCV3 7.1.1 for few days for H96pro+ 3GB/32GB DDR4.
Overall happy with it.
Brief feedback here :
Heat is hot on my box here, was running upto 80degC max for my previous stock 6.0 from from which was around 70 degC max.
Then compare to stock 7.1.1 dated 2017-06-19, this is much stable but hot. That stock is running 7X degC max but only problem that I not happy is frequently pop-up something "Blah Blah app is not responding, wait or close app".
For the heat problem, I decided to mod my box a bit.
Previously I was only have few tiny holes on top of the CPU.
So I went further to make big hole for 3CMx3CM fan.
Now it has max. temperature around 60degC.
You may only view thumbnails in this gallery. This gallery has 7 photos.7 Photos
Originally posted by muncheno View PostBeen using SCV3 7.1.1 for few days for H96pro+ 3GB/32GB DDR4.
This h96 boxes really need a mod, for it to have good temps!
Originally posted by wwmoggy View Postadd holes to side and bottom of the box also add feet raise the bottom 1/4 " to improve airflow I am down to 30C 36c max using a 80mm USB Fan
Lastly I want it to look nicer as this located in my living room.
36degC definitely impressive.Last edited by muncheno; 26 July 2017, 01:24.
The Case that comes with the H96 Pro+ is not a case it is a Coffin, It does not breath there is not enough Ventilation to keep it cool.
I put the Logic Board out of my 3gb/16gb H96Pro+ into a case for a M9X just a small mod to it to that the top is about 1/8 inch off the Bottom of the Case It runs much cooler this way if you want it to run even cooler just sit the Box on a Antec Mini Notebook Cooler that does the Trick but it does take of of your usb slots but with the M9X case you have access to the two that are hidden on the Stock Case.
Since I had spare Hardware and it seems that the Stock Case should be discarded for just about anything else.
hi, I'm stuck with what rom to use on my ddr4 3\32 h96 I'm after 7.1 with everything working on it, that I can just flash and it works. as all the roms I've tried have had remote and sound issues.
but I haven't tried a custom rom yet as there's so many on here I don't know what one to use.
I only tried to up grade due to the bad 6.0 stock issues and hoped 7 would fix it all but just made it unusable.
can someone please point me in the direction of a good working rom to get my box working again?
or the stock 6.0 rom as I know that worked.
There are currently 2857 users online. 2 members and 2855 guests.
