    did you root the box ?
      Yes it is rooted with Magisk.
        @ Devang,
        Would you happen to have an Alfawise? I just got an arm load of China Boxes for Christmas Gifts. The single new Alfawise is the only one that does not reboot to recovery. Same Nandroid back-up on all boxes. Nandroid image taken from original Alfawise (SCV6).
        Have not tested reboot issue with my original Alfawise(Still siitting at SCV4).
          Thanks Reaper,
          I have received the box couple of weeks back from Gearbest. It says Alfawise H96 Pro+ on the box and looks original. The only odd thing I have found with the box is RAM. There is no info on chip about DDR3 or DDR4.
          Its only reboot issue which is not a show stopper. Appreciate all the help.
            Originally posted by devang View Post
            Thanks Reaper,
            I received an Alfawise Box from gearbest last week, there should be printed writing on the PCB saying if it’s DDR3 or DDR4
            I’m running the Android TV rom and have the same reboot issue but like you said it’s not a show stopper
              hmm thks for the tests, i will check if i messed something in the sound!
              I have alfaWise analog r-tv box s10
              on the original firmware ( jnw_s912_ui01_r-tvbox-s10_9377_mac_20170912) I have the read speed of ROM (Toshiba THGBMFG8C4LBAIR ) - 106Mb/s
              this firmware read speed only - 60Mb/s
              can you fix this?
ID:	674925Click image for larger version
                Thanks for this great universal ddr3+ddr4 ROM.
                In the last months it was horror and very confusing with the different roms and i bricked a ddr4 h96pro...
                But something seems not 100% okay.
                Last night, I used Kodi, after I slept in and waked up, the box was completely frozen.
                Best regards,
                Dirk
                  I ordered that one US plug this morning . then found an old one from a USB hub that is the same . new one shipped already
                    can you fix this?
                    Go back to original and try again...maybe it is 64bit issue?
                      Hi,I haw flash scv4 then flash ota scv6,all flash is ok.Buth I haw notice my wi fi is unstabile,drop down and up,in last stock rom wi fi for me is stabile and strong.What is wrong and how I fix this,superceleron? Thanks!
                      Poslano sa mog Mi-4c koristeći Tapatalk
                        Hi ,
                        moved the Question to here , better for Superceleron and Forum ,
                        greetings / gefattern
                          Originally posted by gefattern
                          Hi ,
                          Ok.Thanks
                            Was well happy with this, but as used more i got alot of freezing and reboots
                            I did install Magdisk, i wonder if that has anything to do with it?
                            Pretty gutted as was loving the changes.
                            Will i have to go back to previous rom/s?
                            Oh! i have this on my RBox Pro 3g
                              The box UI is showed as 1920x1080 in cpu-Z even if the resolution is 4K 60 FPS, Is there any work around for that ???? The youtube app or any other app will never display in 4k
                                if i flash again - all is ok - i have max speed 106mb/s
